996 Forum 1999-2005
Traction Control Off
Old May 17, 2007 | 12:45 AM
996 Cop's Avatar
996 Cop
Default Traction Control Off
Tried performance driving my Carrera 2 with the Traction Control off to see how big a difference it would make. The difference was astonishing. The back end slides out on command, but you have to work a little harder to get it back. With T/C on it builds confidence in your driving.
The only thing better is the Carrera 4, but with the extra weight it hurts acceleration slightly.
The Carrera 2 with T/C is a good compromise.
Old May 17, 2007 | 09:10 AM
Paul 996's Avatar
Paul 996
Did you simply push the TC button momentarily which does not fully deactivate it or did you follow the procedure in the manual to hold down the TC button a few seconds to fully disable TC/ABD, etc. See manual in the TC section for details.
Old May 17, 2007 | 11:57 AM
wwest's Avatar
wwest
You must mean PSM....
TC, Traction Control, is used pretty much exclusively to prevent wheelspin/slip, differentually (providing "virtual" LSD functionality), or equally, resulting from too much engine "DRIVE" torque for roadbed conditions.
It is therefore my understanding that absent any such longitudnal slippage TC does not come into play, activate.
Stability control, on the other hand, will always keep you from "wagging" the tail.
An interesting aspect of the Porsche stability control is that its onset, individual activation times, is somewhat delayed in order to give the more expert Porsche driver time to "sense" the event and react accordingly.
In my 2001 C4 what I have found, for instance, is that if I feel, sense, a tad bit of overstear and quickly crank in the correction, a bit of counter-stearing, the stability system simply doesn't activate at all. Whereas in my 2001 AWD RX300 the stability control kicks in, typically, before my seat of the pants sensor system is even aware of the "event".
Old May 19, 2007 | 12:24 AM
996 Cop's Avatar
996 Cop
I just pushed it until the light came on and said Traction Control Off.
Old May 19, 2007 | 01:11 AM
arr0gant's Avatar
arr0gant
Now that i'm used to the POWER of my TT, I ALWAYS turn off PSM in the dry!! With 4WD and good stickys, you just don't need it, matter-of-fact, I think it's more dangerous with it ON!!!!
Old Aug 24, 2013 | 03:14 AM
venom914's Avatar
venom914
Where was the button located. I have a 2000 911 c2 mk1 and i dont know where the button is to turn off the traction control.
Old Aug 24, 2013 | 09:58 AM
ditto's Avatar
ditto
Traction control rocker switch is to the right of the steering wheel and left of the climate control.
Old Aug 24, 2013 | 12:17 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
You probably don't have one, it was an option.
Old Aug 24, 2013 | 02:12 PM
bornrich's Avatar
bornrich
TC is only in early cars with a LSD. I have it on my 99 C2.
Old Aug 24, 2013 | 02:21 PM
knfeparty's Avatar
knfeparty
Is this for MK1 cars with TC only or does this also apply to MKII cars with PSM? I've been using a momentary push and the car still primes the brake pedal when I'm in high-g states and goes instantly to full ABS if I so much as brush the brake with my left foot.
Old Aug 25, 2013 | 11:20 AM
BAD.TAG's Avatar
BAD.TAG
To fully disable systems in Mercedes, it was usually just a case of removing the ABS fuse. Has anyone ever tried that route with a 996?
Old Aug 25, 2013 | 11:28 AM
wwest's Avatar
wwest
TC is an LSD (and MORE), no mechanical LSD required as it would be useless.
TC acts to quickly...
Old Aug 25, 2013 | 01:53 PM
bornrich's Avatar
bornrich
As far as my research has indicated TC in only available in the MkI C2 WITH a mech LSD. I know this as I have one. TC is not an LSD, it is a separate system. I run with mt TC off when I autocross and track my car. I can feel the LSD working. The only way to verify you have a mechanical LSD it is jack up the rear of the car and rotate one wheel. If the opposite wheel is turning I the same direction, there it a LSD present. If it rotate in the opposite direction you have a open diff.
Old Aug 25, 2013 | 03:00 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
Or if the likited slip disks are worn out, the other wheel won't spin at all.......like it doesn't on mine.
Old Aug 26, 2013 | 10:46 AM
wwest's Avatar
wwest
TC, Traction Control, can be used, and is used, to "simulate" a mechanical LSD.
TC can/will apply, QUICKLY apply, individual braking to whichever, or both, rear wheels having lost roadbed traction. It will also dethrottle the engine, sometimes severely so, in order to help regain traction.
"..I can feel the LSD working..."
Sure, like I can "feel" the front wheel "driving" in my C4.....
For the factory to ship a car with TC(/LSD) and a mechainical LSD also would undoubtedly require a special order.
