Has anyone gone from 265/35-18 to 285/30-18's ?
Location: looking for a job ... Colorado by bye 996 C4 :(
I have a 99 C4. OEM tires were 265/35-18 on the rear. I am thinking about going to 285/30-18. Has anyone done this? Would I have any problems doing this?
thanks
thanks
Originally Posted by redridge
your speedo will be slower a bit, smaller diameter, no big deal
I went from 265's to 285's with no problems. Speedo reads fast anyway. Replaced the 265's right after I bought the car, so I can't really compare. Thinking about going back to 265's for my next set because they discontinued the tire I'm using (S-03). I'm thinking about the n-rated Michelin PS2 but you can't buy it in 285's.
Originally Posted by Kevin H. in Atl..
If your wheels are stock fitment with 7.5" fronts, going to the 285 will increase understeer, which is a very bad thing imho.
But wouldn't you only see that when one is one the racing edge of driving?
You can feel it in spirited driving on the street.
These cars are set up from the factory with moderate {substantial, in my opinion) understeer.
Many here (as have I) have changed out their suspensions to reduce understeer, increase roll stiffness, and improve handling. And many of us reduce rear tire pressures to further help balance the car.
If you autocross or track these cars, understeer is a killer.
Why put a larger rear tire on a car whose rear grip already substantially exceeds the front grip?
It doesn't make sense.
Not to mention, last time I checked, 285's cost more, as much as $30/tire.
