996 Forum 1999-2005
RMS paranoia
Old Feb 23, 2007 | 12:47 PM
ML's Avatar
ML
Default RMS paranoia
Just a simple point to prove that one should not go crazy when you car leaks oil.
So, as many, I go away for a few days and when I come back, notice a few drops of oil in the driveway. Wait for a while, happens again (just a bit). I always monitor my oil level closely so I am not stressed about it. Finally decide to bring it in (my car is no longer under warranty - yes, I like to live dangerously!) for inspection. There is a minor RMS leak - actually more a "sweat" which the dealer tells me is of absolutely no concern and turns out that the actual oil leak comes from a defective drain plug gasket, which is being replaced for a few dollars.
Bottom line - stating the obvious here but OIL LEAK DOES NOT ALWAYS MEAN RMS FAILURE. There, I said it.
I just think that my car drops a bit of oil in the same manner as in some traditions, it is polite to burp after a good meal. Eat well - drive fast!
Old Feb 23, 2007 | 12:52 PM
s14roller's Avatar
s14roller
I agree RMS is blown up to be a mucher bigger deal than it is. Even if a car was to drip a few drops here and there, it's more of a annoyance versus a reliability issue. Knock on wood mine doesn't have it but I probably wouldn't lose sleep over it even if it did.
Old Feb 23, 2007 | 01:00 PM
951M471 CarreraM491's Avatar
951M471 CarreraM491
Yeah I don't understand what the big deal is. Every Porsche I've ever owned has leaked oil. It's not like the 996/boxster was the first porsche to have oil leaks
Old Feb 23, 2007 | 01:09 PM
cdodkin's Avatar
cdodkin
It's only a big deal because Porsche set a precedent and replaced some engines that appeared to have ongoing RMS issues.
This then led people to believe that RMS was a catastrophic failure problem, which it isn't.
Case of PCNA doing the right thing, and it backfiring on them in a huge way!
Old Feb 23, 2007 | 01:24 PM
The B's Avatar
The B
Agreed, RMS leak is far from the end of the world...however, If one aquires a brand new 911 at the dealer and the vehicle spends more than 30 days in the shop in the first 8 mos. of ownership for just that one particular issue it is a bit of a...pisser.
Old Feb 23, 2007 | 01:30 PM
evansaero's Avatar
evansaero
I guess porsche owners of the past and present have come to except oil leaks.
That's sad...
I remember stories of my fathers cars. Everyday he was putting oil in it because of leaks. Oh wait that was a buick and Chevy. 50 years ago
Old Feb 23, 2007 | 03:59 PM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
PCNA replaced the engine because that was the only way to stop the RMS from leaking. The right thing would have been to redesign the gear carrier and the crankcase but it was cheaper to just keep on changing seals until vehicles were out of warranty and hope eventually that someone could an engineer a replacement seal that would overcome a defective design.
That's sad...
I agree 100% and there is no reason for any leak to be acceptable especially if the car is under warranty.
Old Feb 23, 2007 | 06:19 PM
88911coupe's Avatar
88911coupe
Agreed that oil leaks in and of themselves are no biggie....just Porsches marking their territory! However, weren't SOME of the leaks tied back to out of round crank which was a more serious matter...correct?
Old Feb 23, 2007 | 06:22 PM
washington dc porsche's Avatar
RMS's are real don't fall for the bs. The good thing is, if you get it fixed at the dealer you get a 2 year warranty.
Old Feb 23, 2007 | 07:55 PM
99firehawk's Avatar
99firehawk
the crank wasnt out of round...................it was not centered, casuing side pressure on the seal and premature failure
Old Feb 23, 2007 | 08:00 PM
ArneeA's Avatar
ArneeA
Could you elaborate on this?
Old Feb 23, 2007 | 09:35 PM
C4CRNA's Avatar
C4CRNA
ML If your car was under warranty they would have changed the RMS in a heartbeat!!
Old Feb 24, 2007 | 04:18 AM
Porsche_Smile's Avatar
Porsche_Smile
well.... i know that my car is out of warr... so it's a REAL thing to me... hope i never see oil under my baby's butt.....
Old Feb 24, 2007 | 09:11 AM
gota911's Avatar
gota911
Newbies Hospitality Director
When I first joined Rennlist, I kept reading about RMS and in some cases engine replacement. Since this is my first Porsche, I was a little concerned about RMS (OK, I was VERY concerned). After being on the forum for a while, the more I read the more I learned and the "concern" lessened dramatically. Knowledge is a good thing!
About 10 days ago I had a defective drive shaft coupler that was throwing grease on the right rear wheel and suspension parts. The local dealer replaced the drive shaft under warranty. When I picked up the car the invoice also stated that they replaced the leaking RMS (warranty). I had not noticed any leaks or oil on my garage floor . I noticed that the clutch felt lighter after the RMS replacement, so the RMS could have been leaking "internally," causing some oil to get on the clutch plate. Not sure about this because I didn't get to talk to the tech who did the work.
I agree that RMS is over blown in the Porsche community. Not catastrophic, just an annoyance.
Old Feb 24, 2007 | 01:21 PM
RMS's are clearly serious enough for those who claim "a little oil leak means nothing". Seems that every time there's a leak, a board member goes to have it checked out and repaired. I'm waiting for someone on the board to say, "I've let my RMS leak for 1.5 years before I had mine replaced it's no big deal".
