Tension Pulley Help!!!
I posted this over on renntech but no luck with getting an answer. I was hoping to get this done today.
Anyone know how to remove the Tension Pulley (99710211700). I can't seem to brake the nut loose and I don't want to brake the tensioner. I think it has lock tight on it.
Also for those that need to replace the deflection pulley here are the PRT#
#99710211700 Which I'm having trouble with
#99710211800
#99710211900
If you have seen the 3.6 mod video you heard the squeeking when the engine is running cold. I have replaced the 2 deflection pullies and belt, but I still have the squeek. So I'm hoping that it's just that I have not replaced the tensioner pulley.
#99710211800
#99710211900
Only the tensioner roller should be tough to get off. With the other 2, the front bolts should unscrew. The tensioner roller bolt comes from the back, through the lever into the pully and can be tough to get off. Removing the entire level makes it easier. Eat some Wheatee's and try again.
It's the tension roller and I tried going from behind, but can't get it loose. How do you remove the entire level. That's what I need to do
When the oil separator goes, it sounds like a pulley squeak. When it is making the noise, pull off the oil cap and see if it goes away. If it does, this is the problem. This info courtesy of 99firehawk who diagnosed mine. If this is not the problem, I dont mean to scare, but my car made a pulley squeaking sound and it was not the pulleys at all but the diaphram ruptured in the oil separator.
The two rollers I pulled off do not move freely and you can hear the grit or what ever it is in the bearing roller. So I'm still hoping it's just the Tenision roller That I can't get off. This sucks
Brad?? Do you have any special way to get to the back nut
Mine went bad but i paid my indy to do it. he had it back by the end of the day for about 400 bucks and ended up replacing all the pulleys and belt. Scared the squat out of me when it startd making the noise. I hadn't driven it for a few weeks and started to work one morning. I pulled into the shop and he let me borrow a car to get to work.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
I paid $27 for belt and $160 for the pullies. Took about 30 mins except for this stupid Tenision pulley. $400 sounds like a steal now
I guess I'll be taking it in for one stupid bolt I cann't get loose. The bolt is on the back side of the pulley and I have know idea how to loosen it up.
Originally Posted by evansaero
I thought that a coupe months ago and tried what you talked about. Thank God that isn't the problem.
i doubt that the tensoer pulley is bad.............not impossible but i have never replaced on and i have never seen one replaced. try taking the belt off and see if the noise is still there with the car running
