engine overheated, permanent damage?
(been delaying the inevitable) while driving on the freeway. I couldn't pull over on the shoulder immediately and the temperature rose to 250 degrees and flashed for just a minute or two. Just wondering, should I be concerned about permanent engine damage due to the heat?
My guess is you will be perfectly fine. Just throw in a new pump and be on your way.
However I would probably get the oil changed sooner since you may have cooked it a little. Check the color when you check the oil level to see if it's more black than usual. This was my experience and your results may be different.
(been delaying the inevitable) while driving on the freeway. I couldn't pull over on the shoulder immediately and the temperature rose to 250 degrees and flashed for just a minute or two. Just wondering, should I be concerned about permanent engine damage due to the heat?Hit some road debris -- 'detroit alligator' -- and busted driver's side radiator.
This while driving around 65mph down dark and lonely highway 50 just west of Strong City KS.
Coolant ran out of broken radiator connection (at bottom of radiator).
At first, immediately after hitting debris, no signs of distress. No oil pressure, water temperature lights on.
After a moment checked rear view mirror. Noticed a cloud of what was coolant/water vapor behind car.
Starting looking for a shoulder to pull over onto when coolant light came on, then started flashing.
Pushed in clutch. Shifted to neutral and left car coast maybe quarter of mile until almost stopped. On this highway, this time of night, no traffic.
Pulled over and wished I had a cell phone with me.
Anyhow, finally managed to get car into Wichita Ks Porsche service department (next morning) and after new radiator, some brackets, and a fresh fill of coolant/water, engine no worse for wear.
I let engine idle and coast to help remove as much heat from engine's internals as could be removed with steadily dropping coolant level.
As soon as pulled over I shut engine off.
Only started it next morning when I drove it across street -- where flat bed tow truck operator had dropped it off on gas station's parking lot -- from dealership into service area: Total engine running time sans coolant: less than 30 seconds.
One thing you want to be sure of is that cooling system properly refilled/charged with coolant. This Porsche service used reservior that mounted to coolant reservior and allowed tech to pull a vacuum in engine cooling system: Enough so that coolant hosed collapsed.
Then tech closed vacuum valve and opened valve that allowed coolant to be pulled into cooling system.
Nice. No air bubbles. No voids in cooling system.
When I picked up car later that day, I drove it around in town to check for any signs of overheating: This in KS just after July 4th holiday, it was hot!
No overheating.
Hit the road back to CA and made it back safe and sound. Since then, and the accident happened a year ago *last* July, car has been in some very hot ambient temperatures and coolant temperature has been under control.
Engine shows no signs of any ill-effects from losing coolant, but I like to think my prompt action to help engine shed heat load immediately after radiator busted is part of the reason.
Sincerely,
Macster.
