Need a quick answer please - 03' C4S - Twist Wheels: Hollow or Solid Spokes?
Originally Posted by Chrisp3
Is there a way to tell whether my wheels are hollow or solid without taking them (and the tires) off the car?
Actually the hollows feel smooth and rounded around the back of the spokes while the solids have 2 ridges or grooves behind the spokes...I know it sounds like it should be the other way around, but it isn't. And the valve stems on hollows are metal with a visible nut at the base of them. If you have a C4S, it did not come from the factory with hollows.
I have the hollow wheels on a narrow body 996.
part#s are
993.362.136.00, 8x18, 52mm offset, tire size 225/40 ZR 18;
rears are part no. 993.362.140.01, 10x18, 65mm offset, tire size 285/30 ZR 18.
they are VERY light... lighter than my stock 17s, which are now for the winter tires.
part#s are
Originally Posted by pongobaz
for a wide body you want the 11 x 18, 45mm offset for the rear with 295/30 ZR 18 tires.
Originally Posted by Bill Davis
Actually a wide body will even take a 315\30 ZR 18 w\ no pronblem....I bought them and they fit and look great!
I have both. The stock C4S wheels are solid, then I bought a set of "new" hollows off a 2003 turbo on eBay.
Hollows are definitely lighter and fetch a higher price either new or used. To be honest, though, I think the lighter weight is all about bragging rights more than anything else. I've tracked the car with both, and I can't tell the difference. They look the same since I have the full metal valve caps on the solids, and they feel the same on the track.
Those are 993 wheels, NOT 996.
part#s are
part#s are
