996 Forum 1999-2005
Clutch Engagement Question
Old Jul 19, 2006 | 11:46 AM
rmcgookey's Avatar
rmcgookey
Default Clutch Engagement Question
Gentlemen,
How far out are you bringing the clutch pedal (approx.) when it engages? I feel like clutch isnt engaging until later than normal - roughly half way out i'm guessing. I've driven many cars where the clutch engages right when you start pulling off the pedal. Just wanted to check with you guys because i'm curious.
thanks!
Ryan
Old Jul 19, 2006 | 12:09 PM
gota911's Avatar
gota911
Newbies Hospitality Director
My clutch engages about the mid-point of the distance that the clutch pedal travels.
Old Jul 19, 2006 | 02:01 PM
Pugnacious P's Avatar
Pugnacious P
my 996 is a tip, but my 03 Boxster's clutch grips right around mid point and has done so since it was new, so I guess thats how those Germans like them...
Old Jul 19, 2006 | 03:21 PM
justinmm2's Avatar
justinmm2
Really?
My car's engaged almost immediately (near the bottom) when I first got it, and stayed that way for 10k miles. Then I botched a launch, and now it engages mid-way up.
Justin
P.S - without threadjacking, how in god's name does one get a sig? I've looked over every inch of options in the UCP
Old Jul 19, 2006 | 04:18 PM
Botsy67's Avatar
Botsy67
Mine also engages quite quickly, I would say a 1/3 way up and since the clutch is new (<1000 miles) it's very smooth and precise, love it...
Justin,
To add a sig, you need to go to your "Private Messages" tab and in there you will find all the options you need.
Old Jul 19, 2006 | 06:10 PM
JES1680's Avatar
JES1680
Mine engages closer to the end of the travel (away from the floor). I'm guessing I'll need a clutch in a year. Its also difficult to determine the engagement point.
Anyone know if bleeding the system will help with the engagment feel?
Old Jul 19, 2006 | 06:13 PM
1999Porsche911's Avatar
1999Porsche911
Bleeding the system will only raise the engagement point of the clutch.
Old Jul 19, 2006 | 06:24 PM
Mitty's Avatar
Mitty
Mine is at midway, but after the clutch warms up, it feels like it engages higher. Normal?
Old Jul 19, 2006 | 09:13 PM
gota911's Avatar
gota911
Originally Posted by justinmm2
Really?
Justin
Justin - the reason you didn't find a Sig option in your User CP is because you don't have that option. You must be a paying member to have a Sig. Why is that, you ask? Well, Sigs take up extra bandwidthand it costs $$$ for additional bandwidth. Membership is only $18 per year or $32 for two ears. Two year membership cost less than a tank of gas and lasts MUCH longer!
Old Jul 19, 2006 | 10:25 PM
Kirk (the DC one)'s Avatar
Kirk (the DC one)
On my C2 Cab, clutch engages half way up. On my (previous) Boxsters, it was much closer to the floor.
Old Jul 19, 2006 | 10:39 PM
smackboy1's Avatar
smackboy1
I think you need to be a paying member to have a sig.
Back to the question at hand. I think the clutch engagement gets higher as it wears. Mine used to engage about halfway, but now it engages much lower down, after I had my clutch replaced.
Old Jul 20, 2006 | 01:08 AM
RUSSCPA's Avatar
RUSSCPA
Justinmm2
What do you mean "Then I botched a launch, and now it engages mid-way up."?
Why would that change the engagement point?
Old Jul 20, 2006 | 01:44 AM
justinmm2's Avatar
justinmm2
Russ,
Well, because of what happened (let's just say I smelled clutch), my theory was that it had to do with the friction plate. Then again, I'm not very mechanically inclined, so... It was an afternoon I wish I could take back, either way. I assume that at some point down the road (it still has 50-70% life left), it'll be replaced and go back to engaging nearly at the bottom.. I look forward to that day.
Justin
Old Jul 20, 2006 | 09:12 AM
washington dc porsche's Avatar
Just below the brake pedal.
