check engine light -rough idle- tapping noise
cruising @ 75mph, check engine light started blinking, then the idling went rough and tapping noise from the left engine bay-- turned if off and had it towed..
car has 18k miles . owned it less than 2 months. My first porsche. 1999 coupe 996 with tip
Lifetime Member
Lifetime Member
Loud tapping noise from one side of the engine typically indicates is the hydraulic lifters. Either the oil passage that supplies the oil is clogged or the hydraulic lifter's seal has failed causing it to fail.
thankyou so much for the rapid replies-- It's in the dealership-- they just asked for me to authorize a diagnostics test-- to drain oil and pull plugs...3 hrs OUCH! It's like waiting for the surgeons report on that grapefruit size tumor they found beside your left ********!!
i have the tapping noise its nothing its just the purge valve in the emissons system im not fixing it since i don't care about emissions. it does nothing to the performance and the only side effect is a bad idle sometimes. the purge valve is fine in my car its just doing its job (which is why it sometime does the annoying tapping noise) its just that i have a leak in my emissons system somewhere.
