squeaking clutch
My clutch makes a terrible (and LOUD) squeaking/creaking sound whenever the pedal is pressed or released. It sounds like a 30 year old Ford pick-up truck (with the engine off).
I figured that I would have had to replace my clutch by now, but it's still going strong. The squeaking started a little over a year ago and has gotten progressively worse, but the clutch still works great (although it takes more pressure to get it down than it used to).
I was told that fixing the squeak would be a bit of a job, so I have been waiting to have it done with the clutch replacement. I don't know how much longer I can wait though. It sounds brutal.
Any advice?
Any advice?
Former Vendor
Clutch pedal might just need a look at. maybe some dirt in the way, maybe clutchline or cable adjusting... probably no more then a 30 min fix
If your in LA, drive here
If your in LA, drive here ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Technical Guru
cable adjusting
Originally Posted by Paul Marangoni
I was told that it was the master cylinder.
If the noise is coming from the bellhousing area, it may be a very common and well known problem with then clutch release lever. It was redesigned shortly after the start of the production of 2000 996. There is a TSB about it. This would be a warranty item if your warranty is active. The bad lever will eventually cause clutch slippage during hard, quick shifting.
Originally Posted by JasonAndreas
If the squeak is coming from the transmission more than likely what your hearing is the release bearing riding along the guide tube. Porsche updated the release bearing (see image below) and now specify that you lube the guide tube with Optimoly MPO (its not regular white grease). Originally everything was installed dry. The fix is simple but requires that you drop the transmission to get to it.
If anyone can find me any Porsche literature that spells out this fix, please send it to me and I'll take it with me to a dealer.
Thanks!!
The sound is definitely coming from the transmission area. This could be it! Is there a TSB for this? I am still under warranty until 100k (I bought an extended warranty that is supposed to cover everything) but I didn't think that the clutch was covered by this warranty. But then again, although this is clutch related, it isn't really the clutch.
Thanks!!
Thanks!!
Good luck.
Jim
Originally Posted by 1999Porsche911
Paul: I sent you a PM. It should be a warranty item if your car was produced before April 19, 2000.
Technical Guru
my car was manufactured in June of 2000. I guess they still haven't got it quite right! I guess I'll just wait until the clutch starts slipping and then have it replaced. I wonder when that will be?
Don't go entirely by the production dates listed in the TSB they were very rarely correct with previous models. The vehicle identification, engine or transmission number are also usually listed (those have also been off but only by a 100 or 2). In this case you want a transmission number newer than G9600 1018220 but even if you are already have the updated release bearing your problem should still be a warranty claim. The squeak is probably either coming from the clutch slave cylinder or from the lack of lubrication on the guide tube and the where the release bearing contacts the release lever.
