996 Anti-Sway Bars??
Originally posted by Viken Bedrossian:
<STRONG>How about the factory 996 GT3 adjustable anti-roll bars?
Front is 5-way adjustable and rear is 4-way adjustable.</STRONG>
Are those drop links adjustable?
Dan
Originally posted by scott watkins:
<STRONG>Viken... is it true that in order to use the adjustable bars, you have to install the coilovers???</STRONG>
I was able to mount them onto my stock set up. It wasn't easy, but it worked. Coilovers usually use an adjustable collar as a mounting point in the rear...makes it easier to adjust to get the right fit.
Keeper of the Truth
RL Technical Advisor
Hi Gents:
If I can inject a point about the adjustable droplinks,........
Without the ability to remove any swaybar preload, you can have some pretty serious crossweight problems. I've seen this ruin a very careful job of corner balancing many times.
If achieving better handling and adjustability is the objective and you are willing to spend these kinds of dollars to accomplish this, do this right and install the GT-3 adjustable droplinks.
Keeper of the Truth
Originally posted by Steve Weiner-Rennsport Systems:
<STRONG>If achieving better handling and adjustability is the objective and you are willing to spend these kinds of dollars to accomplish this, do this right and install the GT-3 adjustable droplinks.</STRONG>
<STRONG>
Steve, are GT3 drop links different from what's pictured above?</STRONG>
<STRONG>
IMHO, its an absolute necessity.
<STRONG>
Without the ability to remove any swaybar preload, you can have some pretty serious crossweight problems. I've seen this ruin a very careful job of corner balancing many times.</STRONG>
<STRONG>
I have a question. If you are using coilovers wouldn't you be able to remove the preload by adjusting the height of the collar on the shock? Sorry for the stupid question just trying to figure out why the threaded links are necessary. Is there such a part for 993's?
Greg
Hi Greg:
On the rear suspension, you may remove the swaybar preload by raising or lowering the upper droplink mounting collars on the shock body by rotating them.
The 996 GT-3 front bar needs the adjustable droplinks as the geometry and lengths are different. PM has those but they are VERY spendy. No aftermarket pieces are available unless they are one-off custom jobs.
993's do not need rear adjustable droplinks as you can see, but you can use them on the front, ala 993 RSR.
As always, the car must be sitting on the ground when these adjustments are made.
