Another stupid coolant question
Lifetime Member
Lifetime Member
I ordered 1 gallong of the Porsche coolant per part number that was given to me on this board 000-043-301-05 from Pelican parts.
When I compared with the existing coolant in the car the color is different. The existing stuff is yellow color, and the new stuff I just received is pink.
The bottle also have no mention of G12, just says G-30-91-EF
Any ideas? Should I mix this with the existing coolant?
after picking up my car from the shop (coolant -tank crack) i noticed the new coolant color is pink.. but regardless, there is a discussion on this on renntech
Lifetime Member
Lifetime Member
Thanks, based on the information I have been reading on Renntech Porsche switched to the pink stuff in 2002 and can be mixed in and used together with the yellow stuff.
Lifetime Member
Lifetime Member
Originally Posted by marlinspike
The coolant on the right in that picture looks like it needs changing, not like it is yellow stuff that is still useable.
No, the green is a different color of coolant, and the oxidation turns it to orange.
Any G12 or G12+ coolant can be used. VW also uses it. G12 is pink and G12+ is purple. It's OK to mix G12 with G12+. G12+ is an compatible with G11 and G12 is not. Generally green coolant is the old type with silicates, more suitable for iron block engines.
