996 Forum 1999-2005
obvious reason why no LSD on 996s?
Old 06-23-2002, 11:20 PM
spinning disc
spinning disc's Avatar
Post obvious reason why no LSD on 996s?
i've searched the archives (performance and 996).
was wondering about the lack of a limited slip differential on the 996 chassis. PSM obviously is supposed to do this, but it will fry the brakes and my understanding is PSM would die a slow death if left on during track days. so, in fact, there is no LSD.
is the partyline thinking that since the most weight is over the driving wheels, the need for an LSD is precluded?
strange, indeed.
Old 06-24-2002, 02:58 AM
Loren
Loren's Avatar
Post
Only the 1999 Carrera's were offered with Limited Slip it was then replaced with PSM.
(except of course the GT3 which had it all years)
Old 06-25-2002, 08:23 PM
wwest
wwest's Avatar
Post
I have no idea at all what the "partyline" thinking might be but I'll take PSM's traction control mode over any mechanical LSD any day of the week.
Try it, you'll like it!!
Old 06-25-2002, 11:34 PM
kenkamm
kenkamm's Avatar
Post
In my previous car, a 2002 M3, the DSC system (practically identical in function to PSM as far as I can see, with the capability to brake any individual wheel) is coupled with the new fangled differential that can send up to 100% of the torque to either one of the rear wheels. So, there is both mechanical and electrical "help". Not that this answers any questions, but it's a data point at least.
Cheers,
Ken
Old 06-25-2002, 11:54 PM
Mike in Chi
Mike in Chi's Avatar
Post
blackdawg
"my understanding is PSM would die a slow death if left on during track days."
The Porsche Driving Experience cars have the PSM on constantly. In fact, it can't be turned off on those cars. It doesn't fry the system there. I understand with some drivers it gets a lot of use
Old 06-26-2002, 02:36 PM
Ed Newman
Ed Newman's Avatar
Red face
No PSM on my car now, no PSM on my waiter. I wanted LSD but PAG thinks they know so well what we want. Why couldn't they leave it as an option. If PSM is all that for tracking, how come the Cup Cars and GT2/3 don't come with it???
I want my LSD!
wait, that didn't sound good. I want choices! better.
<img src="graemlins/cussing.gif" border="0" alt="[grrrrrrr]" />
Old 06-26-2002, 02:41 PM
Loren
Loren's Avatar
Post
Ed,
The LSD transmission still shows up on the parts lists... perhaps Gert at Carnewal.com or Porsche Motorsports can get you one
Old 06-26-2002, 04:01 PM
996FLT6
996FLT6's Avatar
Post
Yeah like one of the psters here pointed out woulda been better if PAG offered more options ie PSM/LSD or none. Now it's all(PSM) or none(no PSM/LSD). Is there a reason why you wouldn't want PSM and have LSD instead- I think it's(PSM) a good safety net since we're not as skilled as those race car drivers are? Is it true that all GT3's including street versions in Europe have no PSM? Regards. Mike
Old 06-26-2002, 04:36 PM
Ron
Ron's Avatar
Lightbulb
You can install an aftermarket Limited-Slip Differential in a 996, the 4340 Chromoly, multi-disc unit costs $2200 and is made by Guard Transmissions. I think The Racers Group uses this unit and probably sells it too.
Old 06-26-2002, 07:33 PM
Ed Newman
Ed Newman's Avatar
Angry
Since its not a factory item, it drastically changes classing for racing :-(
Even though it is a nice safety factor, in my opinion, it slows the car and makes it harder to perfect you driving as it interrups every time you get out of shape. Especially bad for autocrossing.
<img src="graemlins/burnout.gif" border="0" alt="[burnout]" />
Old 06-26-2002, 07:40 PM
Turbo-Look
Turbo-Look's Avatar
Post
I'm getting the impression some of us here don't exactly know the purpose of a Limited-Slip-Differential.
An LSD isn't a safety device like PSM or DSC is. It's a go-fast item.
For example, you're at the apex of the turn, and you wanna power out. Without an LSD, and with the amount of power Porsches typically have, you will have the inside rear wheel spinning, sending you into horrible understeer and generally leaving you going nowhere. This is because without LSD, the differential will simply send power to the wheel with least resistance, in this case the inside drive wheel. With a LSD, the differential will "lock-up" at a certain point and allow you to send power to the outside wheel as well. It's great stuff, a pity PAG doesn't think its customers drive hard enough to warrant one as standard equipment. BMW surely does with thier M vehicles.
Old 06-26-2002, 08:06 PM
wwest
wwest's Avatar
Post
And I have the most definite impression that at least one of us isn't aware of some of the functions of PSM and/or VSC (toyota/lexus.
PSM will automatically apply moderate, modulated, braking to any driven wheel(s) that are/is slipping, to the point wherein its rotational rate closely matches the other (or others for C4) driven wheels.
Old 06-26-2002, 10:25 PM
996FLT6
996FLT6's Avatar
Post
Are there any comparitive figures on the track that would suggest PSM would be a detriment to the track versus LSD? And for those who do have PSM-is it that invasive on the track at all? And with respect to the GT2, I know it doesn't have PSM but does it have LSD? And would it be entirely possible to install the LSD from the MY 99 to the later model 996's without PSM but given the fact the MY02 have more power would a '99 LSD work on those at all? Regards. Mike
Old 06-26-2002, 10:28 PM
Palting
Palting's Avatar
Post
Hold 0n, turbo-look and wwest. I think you are both right.
Lets look at a power turn, with the inside wheel losing grip since it is lifting. In a plain jane car (sorry, jane), almost all your power will go to the spinning inside wheel, the one with the least resistance. In LSD, once the inside wheel starts to slip or spin faster than the oustside wheel, LSD locks up the diff so that resistance is increased to the inner wheel, maintaining power to the ouside wheel, the wheel with traction. In a car with PSM, once the system detects that the inner wheel is turning faster than the outer wheel, brakes are applied to the inner wheel, maintaining power to the outside wheel. In addition, PSM will also detect that you are doing a power turn, due to feedback from a gyro measuring centrifugal (or is it centripedal? It's been a long time since highschool) force plus sensors indicating the degree of steering input from the steering wheel, the attitude of the tires and suspension, and the amount of pressure from the gas pedal. Based on all that data, after nanosecond calculations, it determines that you want the car to turn in more than what it is doing, it will preferentially transfer even more power to the outside wheel and less to the inside wheel. If you have an AWD vehicle, there are two more wheels that PSM can manipulate to make the car behave properly. AND, if I understand the interaction between PSM and engine management software correctly, if you need more power than what your right foot is supplying, the engine management software WILL supply more power, all in an effort to keep you from flying off the course.
PSM is a safety item with a go-fast soul. LSD??? Who needs LSD??? BMW can keep it, together with their powder puff M engines .
Old 06-26-2002, 10:39 PM
Palting
Palting's Avatar
Post
Oh, yeah. And another thing. (sorry if this is getting too long). On the AWD sytem of the TT and the C4S, up to 45% of the power can be transfered to the front wheels. And, again, if I understand the press releases and advertising blurbs correctly, this can also be applied differentially to a single front wheel. I do not believe that this is a function of PSM, but a function of the viscous coupling of the AWD system. this has a tremendous effect on maintaining neutrality in fast corner, putting the car on rails. LSD???? What is LSD????
Quick Reply: obvious reason why no LSD on 996s?
