Techron? The good the bad the ugly...Opinions Please
Hey, anybody have an opinion on using techron?
I was wondering if it may be a good first step to fix a intermittent rough idle, before going into costly repairs...
Techron is a good fuel system cleaner IMO. I don't think you are going to find much bad or ugly other than cost.
However I started using Jectron and Ventil Sauber Valve Clean on my 993 and have never switched back. I usually run a bottle of each through the system just prior to doing an oil change. Here is a link where I get it (no afiliation, yada, yada, yada). This reminds me that I need to order some.
https://www.olyonline.com/Lubromoly.asp
Techron works great, it saved me after I had some bad gas once. Just buy it directly from the Chevron station, not very expensive at all. Keep using Chevron fuel with Techron for a month or so, it should help.
Thanks,
I could not find the lubromoly nor the BG 44k products at local auto store, but I did find techron, so I will try it next fillup. Thanks for the help, The web links were helpful!!
Pep Boys even carries it - I've used it in my other vehicles. Techron advises to add one container per tankful when the tank is near empty. Most, but not all fuels have detergent additives, although I believe virtually all premium fuels do. I still use it.
Phil
Phil
