996 Forum 1999-2005
Need help with jackstands
Old Jan 24, 2006 | 10:24 PM
mrcook02996's Avatar
mrcook02996
Question Need help with jackstands
I have read all the lifting posts in this forum, and am left with a few questions. I read about some people using hockey pucks for a pad on the jack and jack stand. My question is how is the puck used on the jack stand? I have the 3 1/2 ton Craftsman stands (with the "v" shaped top) and they don't look like a puck will fit in them. Is there any way to keep the stands from scratching up the jack points? Thanks for your help.
Old Jan 24, 2006 | 10:31 PM
Eli K's Avatar
Eli K
I generally use a puck only when lifting or lowering the car with a pneumatic jack
Old Jan 24, 2006 | 10:51 PM
Orient Express's Avatar
Orient Express
The hockey puck idea if for lifting jacks only, not jack stands.
A method that I use to protect the jack point from getting scratched by the jack stand is to dip the cradle end in PlastiDip. This works very well, and puts a high grip surface on the jack stand.
Old Jan 24, 2006 | 11:15 PM
mrcook02996
Default Thanks for reply
Okay, thanks for clearing things up. I too have used the plastidip for the top of the stand. I wasn't sure it would hold up or not, as it seems the coating remains a little soft..
Orient,
Thanks for the excellent write up on jacking up the car. I will try to follow that procedure, hopefully with no problems.
Old Jan 25, 2006 | 12:45 AM
Orient Express
To get the best surface, You dip in plasticoat, let dry, dip again, let dry, etc. and build up a thick coat. I think I put 10 layers on, and it is tough as a piece of nylon.
Old Jan 25, 2006 | 02:35 AM
SANDOVAL's Avatar
SANDOVAL
Griots sells Jack Stand pads. I have them for my griots J-stands. If you have race deck type flooring they are a must have.
http://www.griotsgarage.com/search.j...xt=jack+stands
Old Jan 25, 2006 | 10:25 AM
viperbob's Avatar
viperbob
Former Vendor
Or you can just get a jack stand that is the best I have ever used as far as sturdiness and largest soft pad area that touches the car.
http://www.drivewerks.com/catalog/sh...ACHyd1_pg5.htm
Old Jan 25, 2006 | 08:52 PM
Carrera Mike's Avatar
Carrera Mike
Cool OR
I had these made at a machine shop for my old 993. They still work for the 996
The round piece actualy bolts on to the jack adapter.
File Type: jpg
File Type: jpg
Old Jan 25, 2006 | 09:52 PM
Big6Dad's Avatar
Big6Dad
WOW....that is a very nice set up Mike...
Old Jan 25, 2006 | 10:11 PM
Carrera Mike
Thank you Dave.
