M030 on my 996 / Pics.
I'm installing coilovers tomorrow or Friday which will be a little lower than even Euro M030 and will let you know. I doubt very seriously that lowering it appx 1" front and rear is going to cause a problem with the 285s given the vast amount of space there stock.
Ben, I thought you were doing the RoW 030, what made you decide on coilovers? Should be a very cool setup. Did you get the H&Rs?
My car goes in for the RoW 030 next week!
Doug
Doug
Hi DJ. I decided to do the H&R coilovers w/ GT3 adj sways. They should go in tomorrow (if they make it here early enough). The reason I chose this setup is because it is much more versitile and I can grow into even more aggressive settings later if I want to. Also, I figured if the GT2, GT3, and all Ferraris have coilovers, that was probably the best way to go. Not to mention, Steve at Rennsport was pestering me to "do the right thing" :-)
No, GT3 sways came from Belgium (MUCH cheaper). Will start out with the settings recommended by the shop. They service two Cup cars so I figure they know what they're doing :-)
Originally posted by ben in lj:
<STRONG>My 01 from the ground to the "apex" of the wheel well was about 26 1/2"</STRONG>
"Is that front or rear (with your current 030 setup I preume) ?"
That's the standard US suspsension (ie: NOT 030). The front and rear were within about a 1/4 to 1/2 inch of each other.
