Brake fluid change every 2 years?
I just got a coupon to change the brake fluid on my '02 996. Dealer recommneds every 2 years. Special price is $169.00
1) Do I really need to change brake fluid every 2 years? My mileage is 15,000.
2) Is $169 a good price for our cars? Or can I take it to an independent?
Thanks.
Thanks.
If you don't track the car, once every 3-4 years is all you need if you have no symptoms of spongy brake pedal. Every 2 years is overkill for most drivers. For street driving, the rule of thumb barring any symptoms, is with brake pad change.
I do it every 2-3 yrs. There is a risk of rusting the ABS sensor as well as inefficient braking. It's not end of the world but I'd do it every 3 yrs for sure instead of waiting until pad change (usually 4-5 yrs depending on mileage).
Its every two years regardless of mileage if you want to follow the factory recomendation. You could drive zero miles and the brake fluid is still going to absorb water.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Yup,
My 996TT sat in storage for 16 months (don't ask); brake fluid was flushed pre and post storage....zero miles on the fluid.
As has been said, it's all about moisture content.
I run stock fluid in the 996TT and I run Castrol SRF ($70/can) in the track appliance; same rule applies to both.
My dealer sells the Porsche brake fluid at $23/bottle. It's good for one flush plus some left over. $99 seems very good price! You can also do it yourself or have an independent shop do it.
What about the ABS? I bleed my system everytime I change pads as well as track weekends when I already have the wheels off but for a TRUE flush I heard that you cannot just pump the brakes or use a power bleeder because of the ABS.
Just to emphasize what Sloth said and explain the science of Brake fluids. Brake fruid is a Hygroscopic liquid which mean it absorbs water over time. Not only will this affect your braking over time but the moisture lowers the boiling point of the fluid and causes internal corrosion in the brake system.
Change it every two year irrelevant of mileage, track use, etc...
Super Moderator
Needs More Cowbell
Needs More Cowbell
However, even if you don't do this, the small amount of brake fluid left in these channels compared to the rest of the system, by volume, should not make a great difference, but it should be done nonetheless.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Thanks for the 4-1-1 Lewis ![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
Just remember, no rebadging your brake fluid to make people think you're running Castrol SRF when you're running stock fluid
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Sorry everyone, inside Cayenne forum joke
