Engine/Radiator fan DIY switch ??
i recently ran the wires for adding switches to run the radiator fans and the engine compartment fans. I was going to use a Footwell Light Switch, but when I tried it the fans only ran when the switch was held down. Apparently it was designed to control a relay and it not a simple on/off switch. Does anyone know of a Porsche tip switch which will accomplish this, i.e. keep the fans on until I switch them off. I would prefer not to mount a non-standard switch.
