996 Forum 1999-2005
fun weekend project - pep boys muffler bypass pipe
Old 12-03-2006, 06:01 PM
  #61
ga911
ga911's Avatar
Russ -
Do you have the Summit part number for the 90 degree pipe? They have about 300 SKU's in s/s alone. Thanks.
Old 12-03-2006, 09:26 PM
  #62
996 MBA CFA
996 MBA CFA's Avatar
Russ, those muffler bypass pipes look great. You're giving me ideas. My quad exhaust on a narrowbody might be had for cheap if I take your approach. Thanks for posting the pictures.
Originally Posted by Russ Murphy
Here's the result of my muffler bypass project. I didn't want to throw down 6 bills or whatever it is currently for the Fabspeeds, but have decided I want 40-50 lbs less on the car at the track, so I ordered two 90 degree stainless steel mandrel bends from Summit Racing and two Magnaflow polished stainless double wall round tip (both in 2 1/4") took them to a muffler shop and had them barely flare the end that goes onto the cat and weld the tips on(not a great job on the welding). I finished them with the angle grinder with 3M scotchbrite velcro pads and voila.... two pounds a piece and a total of $140 all told. So you can get something nicer than the Pep Boys version without too much trouble.
Old 12-03-2006, 11:26 PM
  #63
Russ Murphy
Russ Murphy's Avatar
Originally Posted by ga911
Russ -
Here's the Summit SKU You have to cut the tip end to move the tip as close as possible to the bend.
Jim,
So add the set screw to back things up. Thanks.
Old 12-04-2006, 12:56 AM
  #64
ga911
ga911's Avatar
Thanks!
Old 06-27-2007, 08:45 PM
  #65
ubergeek
ubergeek's Avatar
it looks like the summit part is no longer available. Can someone please post the exact size of the pipe needed? I have found similar pipes online but need to make sure i order the correect size (especially lengthwise)
thanks.
Old 11-02-2008, 05:36 AM
  #66
buz3rd
buz3rd's Avatar
guys would they work for 997s?
similar 90 degrees 2 inch pipes?
can someone also tell me why we cant use the pep boys pipes for long term?
other than the looks of it, i reckon they work same like fabspeed?
If it looks ugly, cant we weld some nicer looking pipes on it?
Quick Reply: fun weekend project - pep boys muffler bypass pipe
