996 Forum 1999-2005
Problem with lights: Always On.
Old Aug 3, 2005 | 10:22 AM
Dale Gribble's Avatar
Dale Gribble
Pocket Sand
Default Problem with lights: Always On.
I seem to be having a problem with my lights. Even when the switch is all the way to the left (off position), my lights are on (not daytime running lights, but like full out headlights, lights at the back and the orange indicators). Does anyone know what the problem might be?
I'm pretty useless with electrical stuff, the only thing i can see is that one of my orange corner lights is not working.
Old Aug 3, 2005 | 10:49 AM
mitch236's Avatar
mitch236
all the way to the left is on, the switch needs to be in the middle
Old Aug 3, 2005 | 10:50 AM
Dale Gribble
Pocket Sand
r u sure?
i've never had the **** anywhere but on the left for off..gonna go double check now.
Old Aug 3, 2005 | 11:09 AM
RLandis's Avatar
RLandis
I finally found someone who's got me beat!!!!!
Old Aug 3, 2005 | 11:10 AM
Dale Gribble
Pocket Sand
rofl...UR NOT HELPING!
Old Aug 3, 2005 | 12:56 PM
RLandis's Avatar
RLandis
DeAD-EyE.....I'll say this for you.....you're a good sport!!!! But, I can promise you I'm not lending you my 996!!!! Just kidding!!!!!
Old Aug 3, 2005 | 04:24 PM
Dale Gribble
Pocket Sand
i've got it...the problem is with the aftermarket alarm i installed...probably where the wire was spliced in...or the programming on the unit itself. gonna have it checked out 2morro mornin.
Old Aug 4, 2005 | 03:18 PM
Dale Gribble
Pocket Sand
ok i don't have it figured out.
i disconnected the alarm from the lights and returned it to stock..but the problem still occures.
any other possibilities?
Old Aug 5, 2005 | 12:09 AM
wwest's Avatar
wwest
Canadian Porsches must conform to the DRL law, parking, street, tail lamps and low voltage on with the high beams. But if you have HID the HIDs are on all the time, result of the DRL design.
Old Aug 5, 2005 | 12:21 AM
Dale Gribble
Pocket Sand
understood. but my problem is that the lights (not DRLs) that you would use at night for instance...are on all the time.
i gave G-Tek a call and they said it is prolly a relay that is stuck.
compustar suggested checking that the parking like output on the compustar isn't wired into the headlight relay.
will try these 2morro or monday.
Old Aug 6, 2005 | 02:37 PM
Scouser's Avatar
Scouser
My guess is one of your rear lights bulbs has an internal short or bad earth connection. I had this truouble and it turned uut to be a faulty rear nearside bulb....but the bulb still worked! Yup it still worked fine but the internal earth wasn't connecting and it allowed power to flow through the bulb filament and ths leaving all the lights turned on. Pull out the rear bulbs and see if the problem goes away.
Old Aug 6, 2005 | 03:11 PM
gota911's Avatar
gota911
Newbies Hospitality Director
Remove the fuse panel cover. Reach up and grab the wire bundle, and pull... really hard! Keep pulling until the lights go out. Problem solved!
BTW, you can thank Richard Landis for this idea, because he inspored me! I just asked myself the following question. I said "Self ...what would Richard do?" That's when this "low-tech" idea hit me!
