Faulty tappet - expensive to fix?
Does anyone know whether it is expensive to fix the hydraulic tappets of the Variocam plus mechanism (by an authorised dealer)?
Any adverse effect if you let the car run with a faulty tappet? Is it safe to do so?
Guys, one more question. What will happen if the tappet gets sticky? Will it affect the A/F ratio and cause the vehicle to backfire. The reason I ask is that my 2002 996 will somtimes backfire during moderate acceleration. Thanks in advance.
1200 GBP to fix at the OPC - thats $2000 usd
NOT CHEAP
Can you get a bent valve from sticky tappet? I haven't heard of this issue on 996. I assume your 02 is out of warranty. Maybe you can get PCNA to pay for partial cost if your warranty just ended and you have low mileage. Make sure the diagnosis is done properly - ie spend the money to have it properly checked. I'd do it at a reputable dealer if you think you have a chance to get any money from PCNA.
Try to clean up the top of the engine by sucking ATF into the intake with the engine running. Remove a small vacuum line and insert it into a container of ATF. Let the engine idle while the fluid is sucked in. Turn off the engine after sucking in about 1/2 quart. (there is no danger if more or less fuid is used) Let the car sit for 30 minutes.
Wait until dark, and then take the car for a spin to blow out the ATF. The car will smoke like hell as the fluid is burned and will be less embarassing in the dark to drive down your street.
This procedure quite often will rejuivinate the valves and lifters.
My 996 has a few sticky lifters, they clack to the point that my car sounds like an older 911. I'm fighting with the dealership who said its "normal". I don't think you risk doing valve damage because if anything, the collapsed lifter will result in less valve lift rather than more.
Lifter problems are not unheard of with 996's. The dealerships stock a product that you can add to your oil to possibly free up sticky lifters. It hasn't worked for me, but it may work for you. Give them a call and find out what they use, if that doesn't work you may need to have the lifters replaced.
Originally Posted by Darren
This is just bad advice. This works great on 1967 Chevy Pickups, but on a 996 with multiple cats, do so at your own risk. Besides, he was complaining about a lifter problem, what could that possibly have to do with combustion chamber carbon deposits?
All it takes is a little grit stuck on a valver to get it stuck. Running ATF through the intake can help remove this grit. It is also a great preventative of valve train problems and I do it in all my cars, new and old once a year. I have no idea why you mention the CATS, the use of ATF in this manner does not damage them.
A more extreme methed is to use water which will create a steam and also soften and remove carbon from the upper engine. This does a great job but can clog the cats if large pieces of carbon are dislodged. In this case, cats should be removed prior to treatment.
I suggest that YOU try this procedure and maybe you won't have your sticky valve problem, as it IS NOT normal or common in the 996 unless you are running 0W-40 in hot climates.
My car is under warrranty
But your reply shows a basic misunderstanding. When you put ATF into the intake system of your car, it will NEVER come in contact with a lifter.
