996 Forum 1999-2005
Becker Monza
Old Jul 12, 2005 | 12:42 PM
Eli K's Avatar
Eli K
Default Becker Monza
I have a line on a few brand new European spec Becker Monza CD/RADIO/MP3 head units. Two things to consider AM is virtually useless,the FM tuning goes in intervals of .1 whereas the US tunes in intervals of .2
Price will likely be about $440-$460 per.
Cheapest I found in the States is $525. Specs below
Any interest? Should I look further into it?
Becker Monza 7882 CD / MP3 tuner.
The Becker Monza MP3 is the perfect combination of radio, CD and MP3 Player. With excellent sound quality and superb technical characteristics, it is perfect for all music lovers!
Enjoy up to 12 hours music non-stop with MP3 discs, whilst remaining compatible with conventional audio CDs. An excellent tuner, high power output stages as well as a first-class sound, the Becker Monza MP3 makes it all possible.
Technical Information:
Features: Dot matrix, white display, user-specific programming, easy-to-control (ETC) soft key menu control, coded security, snap-in chassis (no mounting frame / cradle required).
Tuner: FM, MW, LW, SW (49 m), 48 station memory (12 for each band), AutoStore (MW, LWt sensitivity / impedance: 2.2 µv/150 ohm, frequency range: FM 30 Hz ... 15 kHz, AM 50 Hz ... 3 kHz, search range FM/MW/LW/SW (kHz): 100/9/3/5
Single CD / MP3: Full logic drive, skip function, direct track selection, random play, repeat, display of elapsed track time, total CD play time and total number of tracks, scan function, last address memory, skip forwards and backwards, scratch-proof loading mechanism holds discs by the edges coupled with shock-resistant playback mechanism, compatible with CD, CD-R, CD-RW, mixed-mode, MP3 and multi-session CDs, menu selection for various MP3 listings, variable bit-rate 8 - 280 kbit.
CD Changer Control: Skip function, direct track selection, random play, repeat, display of elapsed track time, total CD play time and total number of tracks, scan function, last address memory, skip forwards and backwards, programmable disc name, track filtering on CD changer.
Audio: Separate source-specific adjustment of bass / treble, tone, balance and front / rear fade; 4 x 30 watts music power, 4 x 18 watts RMS; pre-out: 4 channel, subwoofer or centre speaker pre-out control, telephone-AF control.
Connections/Miscellaneous: DIN-ISO connection, connection for CD changer, telephone mute and telephone AF input, AUX input (except with CD changer), connection for 15 stage speed dependant volume control, subwoofer output adjustable via menu.
Old Jul 12, 2005 | 12:58 PM
redduck996's Avatar
redduck996
i-pods?
Old Jul 12, 2005 | 01:07 PM
Ubermensch's Avatar
Ubermensch
Being new to the world of European cars, I've been wondering how the Becker line compares to other high end manufacturers. Is this thing equivalent in quality to high end japanese stereos? Is this plug an play in the 996 with the stock amp?
Old Jul 12, 2005 | 02:10 PM
bavarian's Avatar
bavarian
Won't work with MOST based fiber optic P-cars built after 2002 as far as I know.
Old Jul 12, 2005 | 02:11 PM
Eli K's Avatar
Eli K
It's a plug and play replacement for your current 210 or 220. Looks identical to the factory unit with the exception of the Becker logo...
Old Jul 12, 2005 | 02:43 PM
Neighbor's Avatar
Neighbor
Any discernable advantage to the 210 or 220?
Old Jul 12, 2005 | 03:29 PM
Eli K's Avatar
Eli K
Yes, it plays MP3s
Old Jul 12, 2005 | 05:05 PM
Gert's Avatar
Gert
The Becker Monza was discontinoud several months ago and was replaced by the Mexico Pro series.
Old Jul 12, 2005 | 05:36 PM
Eli K's Avatar
Eli K
Thanks for the info Gert. Do you by chance carry the Mexico Pro?
