Is a replacement engine a bad or good thing?
So here is the issue. There is a 2002 996 that runs perfectly (in fact better than new), but keeps having a leaky rear main seal. The car has 40,000 miles on it, but the rear crankcase tolerance where the RMS goes is out of specification and continues to leak. Because of this, the car will get a replacement engine and an extended warranty courtesy of Porsche. My gut tells me this is a good thing as the chassis is tight, the rest of the mechanicals have been faultless, and the transmission is perfect. With a remanufactured engine, it seems like the car would be good for at least another 50K miles, but that this engine will need to be broken in again.
What is the consensus on this situation. Replacement engine good? or Replacement engine bad?
I think it is no problem for either you to keep it or for a prospective buyer to evaluate it. New mechanicals and extended warranty...what could be wrong with that?
Comparetively speaking anything would be better than the engine that's in the car right now. Since Porsche is replacing it with a reman. unit there is no need to break it in, as they do that at the factory.
Good luck!
Good luck!
I have about 7K on my replacement
I had a replcement due to a non-RMS issues (they still don't know what happened, or haven't told me but the engine let go -- I think it had a slightly cracked block when I got it from the Porsche dealer, but what do I know).
I was very happy with the process and I am very happy with the results as I noticed it running much better. My new engine (according to Porsche NA, as I called them) was 100% new internal and external parts, and only the block was remanufactured. Apparently this is a typical approach? And yes, it is all broken in and all by the factory. However, I still took it easy for the break-in period.
I personally think this would be a very good thing for overall performance and resale, but welcome other opinions.
it could be that an RMS leak is a manifestation of misaligned transmission.... that new motor going in will no doubt have ANOTHER RMS leak.... personally I wouldn't buy a car with a new motor.
If your car has RMS.. I don't think changing the motor will do any good... it will show its ugly head again.
A while ago and I read this here on rennlist... a porsche engineer suggested that the RMS leak is a manifestation of another physical problem in the motor.... and this problem would be a misaligned transmission -> beyond that I cannot explain nor understand the mechanism by which this incurs more RMS leaks... but from observation on this board... if you had one RMS your getting it again... also if your engine has NEVER had RMS before 40,000 miles, chances are everything is ok and you will never see it. (IMHO)
at the factory... the specialize at putting in new engines... don't know how good a local dealer will be cause they don't do it all the time... know somebody who has a replacement motor and there are still problems...
I got a reman engine also and posted the same question elsewhere. The consensus was it is a neutral.
I have 1500 miles so far and no oil burning which was the reason for the change. I am happy thus far. Took it easy during the first 1000 miles or so and even a little now.
If you keep the car yourself for a few years, a remanufactured engine should be a good deal for you. When you sell it, it may hurt your resale value because there are some Porsche buyers who won't buy a car with a remanufactured engine. Of course when selling, you could play dumb like many car dealers and claim that you have a new and not remanufactured engine.
The person who bought my car considered the newer engine a plus, not a negative. There were potential buyers who were concerned about it however.
As for break-in, my SA told me the replacement engine was run-in at the factory, and to just keep the engine below 5200 for 500 mi or so.
If the engine in my 99 Cab failed today, and I got a new (remanufactured) engine it wouldn't bother me in the least, and I would probably keep my car longer due to the fresh engine and two year unlimited mile warranty that comes with it.
YMMV.
if you are worried about placing well in the pebble beach concours then mismatched numbers will be a negative for you
can they tell you how many miles are on the remanufactured engine? are remanufactured engines essentially used engines brought back to the factory for rebuilding or are they new, straight off the line and put back in the line due to quality issues?
at any rate, a remanufactured engine should have been checked to be within tolerance and theoretically should not leak as your current engine does.
The other plus here is that with the engine out of the car, I can clean and wax the inside of the engine bay much easier than with the engine installed.
