can 996 be dropped with just springs?
Chad never disappoints. Thanks for the great write up. I also came to understand that the spring rate on the stock springs are similar to that of H&R? T or F I don't know but I know that as of yet it's not noticable other than cornering which is much improved. I suspect what Chad is referring to I will experience some time in the future and at which point I'll probably do what Karlooz did and go with H&R Coilovers. Thanks again!
Gerard
Gerard
Gerard,
The H&R's that I placed on my car had less coils, thus have stiffer spring rates. I am still to this day trying to get an accurate measurement vs. stock. If I come across anything, I will be sure to post. As far as basic knowledge goes, the H&R's are in fact stiffer that stock. I guess that's why I like them so much.![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Chad
Chad
Depends if you currently have the US M030 sport suspension. I am perfectly happy with the ride and handling of my H&R springs with the stock sport shocks. Most bouncy complaints seem to come from those who match the stock non-sport shocks with lowering springs.
Wear on the shocks will most likely be accelerated a bit...
If all you really want is a lower stance and don't care about performance, ride quality, etc...and you want to do it on the cheap - just take a torch and heat up your springs. Your car will start to lower as the spring heats up and just remove the heat when you get to the desired height...nothing to take apart, no cost for new parts, and no alignment!! ![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
This is how the guys with the POS cars in highschool used to lower their cars! The ones who had slightly more money would go to the trouble of removing the springs and cutting off a few coils with a carbide blade.
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
![nono](https://rennlist.com/forums/graemlins/nono.gif)
C.
Originally Posted by Chads996
YIKES!!! By doing that you are re-tempering the metal and changing the characteristics of the spring. Big no, no, no, no...
C.
C.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Thanks again for the sig!
I realized...Unfortunately, some folks here are not as versed in metalurgy that you or I may be. Just clarifying for those not in the know.
Kinda goes back to the "accord bounce".
Chad
Chad
Chad and others - this is a great thread. While I understand much better now the value of matching dampers if installing a lowering spring kit like H&R, I'm wondering if I can get away with just an H&R kit given that:
- The C4S currently has 2K miles
- I don' plan on keeping the car more than 18 - 24 months and will only put a maximum of 8K miles in the next two years
- I'm not going to be using it for track purposes. The lowering is being done mainly for aesthetic reasons.
Couple of other questions for Chad and others (admittedly, I need to do further research / reading on all of these questions):
- Is there is "standard" H&R spring set that most people get when lowering? Or is it all a function of how low you want the car?
- If you do go with better dampers to match the H&R springs, what are the recommendations?
Many thanks.
Many thanks.
Originally Posted by Re-animator
For C4S Coupe H&R part # 29466 with Bilstein Sports VN7-4613 and BE5-2994 are the ticket. These Bilsteins are technically specific to the X74 package. Check shox.com. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Originally Posted by C4S Surgeon
X73 or x74?
Originally Posted by mightytaco
Anyone have a full side shot of a car lowered with H&R springs?
http://www.6speedonline.com/forums/s...980#post301980
I think the car looks outstanding with lowered springs.
