996 Forum 1999-2005
Orange Cap Users
Old Nov 30, 2013 | 05:15 PM
  #136
speed rII's Avatar
speed rII
Originally Posted by MiamiC70
What is the benefit of removing the resonator vs. just capping / bypassing it?
Removing the resonator will give the airflow much smoother path to intake.
Wouldn't be supriced to see some hp gain with this mod. IMO
Old Dec 1, 2013 | 12:34 PM
  #137
Chris@Fabspeed's Avatar
Chris@Fabspeed
Former Vendor
Originally Posted by thirteeneast
[IMG][/IMG]
Take it back down to the airbox then its still filtered and theres no need to add a filter to the end of the pipe.
The problem with doing it this way is that the air from the vacuum line could have an oil mist to it ,which will then have to flow past the MAF sensor. I think Porsche specifically put that line after the MAF for a reason. I am still trying to figure out what that line is for, on the Tip & X51 cars.
Old Jan 18, 2014 | 02:14 AM
  #138
passatrox's Avatar
passatrox
Just had to apply a cheap hack to try out if I'd like the sound. Just disconnect the hose from to the HhResonator, take a piece of a thicker plastic bag and put it over the opening, re-attach the hose and clamp it all back = nice sound, suddenly screams at over 5k rpm. I might go for the more permanent solution (or take a nice black bag instead of the white one)
Old Jan 18, 2014 | 10:57 AM
  #139
Imo000's Avatar
Imo000
Captain Obvious
Super User
^^^ I used a rubber glove to test it first too. Only had it in there for a week but the glove was deformed from trying to be sucked into the intake. So be careful not to get that plastic bad sucked into the engine.
Old Jan 18, 2014 | 11:16 AM
  #140
alpine003's Avatar
alpine003
Brings back memories of the BMW guy that left his shop towel to plug up the oil cap and got sucked into his engine when he forgot about it.
Old Sep 15, 2014 | 07:19 AM
  #141
thirteeneast's Avatar
thirteeneast
Its the breather from the gearbox and thats the OEM place to put it? althogh as you say it is after the Maf as opposed to before it.
there is no oil resdue from the pipe ever!.
Old Sep 15, 2014 | 10:54 AM
  #142
33jacket's Avatar
33jacket
buy a silicone pipe for the 996 from ebay for 20 bucks
Pull out the resonator
Cap the hole using a wing number sandwich plug that you can find at lowes in the plumbing departement...it actually looks cool too. This plug is red aluminum that has a fat rubber gromment that you ratchet down with the wing nut and it sandwhiches around the hole and hole opening...totally air tight. If you are afraid of the wing nut working loose just put a lock nut on top of it....
The whole mod costs $25 bucks. Its the exact same mod some are selling online for 200. I did it...I will try to get pictures if I can.
Old Sep 15, 2014 | 11:30 AM
  #143
williamr91's Avatar
williamr91
probably a dumb question, but does one cut the plastic open where the cap/wing number sandwich plug goes?
Old Sep 15, 2014 | 11:58 AM
  #144
Medevack1's Avatar
Medevack1
Good find 33Jacket. I saw your post/pics and yes it looks great I just ordered my silicone hose (E-bay $23.00 shipped) and ill be getting the plug from Lowes Hardware today.
Old Sep 15, 2014 | 12:03 PM
  #145
alpine003's Avatar
alpine003
No, it's already there from the factory. You just need to remove two bolts from underneath to remove the resonator chamber. This will yield you a little more volume in the airbox assembly.
Old Sep 15, 2014 | 12:40 PM
  #146
33jacket's Avatar
33jacket
link for future reference
https://rennlist.com/forums/996-foru...irbox-mod.html
Old Sep 17, 2014 | 04:49 PM
  #147
Medevack1's Avatar
Medevack1
A breather picked up a local auto parts.
ok before I go screwing something up, after reading and seeing all the pics posted this is the onlyone I see with a small breather? Is there a diffrence between the 40AE and the others? is there something i need to know? any info will be great thank you in advance. BTW i have all parts except the small breather.
Old Sep 17, 2014 | 06:47 PM
  #148
alpine003's Avatar
alpine003
n/m
Old Jan 26, 2015 | 08:50 PM
  #149
wucash's Avatar
wucash
Default Where to buy
Where can I buy the orange cap? I looked on Niagara Plastics website and search for item number 273 and nothing comes up. looked on ebay and amazon too.
Someone should sell them on ebay.
Old Jan 26, 2015 | 09:17 PM
  #150
Gonzo911's Avatar
Gonzo911
Rat Balls
Originally Posted by wucash
Where can I buy the orange cap? I looked on Niagara Plastics website and search for item number 273 and nothing comes up. looked on ebay and amazon too. Someone should sell them on ebay.
Don't you just buy a can of Gillette Shaving Cream?
