996 C4S Suspension Question - M030, X73 or X74?
The M030 is still available but unlike the C2, it costs nearly as much as a full coil over set up for the C4S. If you're suspension is old and tired, i would either stick w/ what you have now and replace the worn areas, or go aftermarket. Ohlins is likely the best, Bilstein PSS9/10 right behind that, I know a lot here like the H&R set up or be adventurous (and cheap) and give offerings from Feal. Based on some of the feedback here, Feal looks like a pretty good bang for the buck.
