Need to replace one of my city lights.
The left front city light (parking light) bulb is out.
#1 how do I replace it?
#2 is there another option I can go with to get rid of the yellowish light they produce and get a white light? If so, is there a place on-line that I can buy them?
#3 What bulb type is it?
TIA!
TIA!
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
TIA!![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
TIA!
Check your owner's manual. It tells you how to pop out the headlight assembly and replace the bulbs. If you don't have a manual then go to the dealer and buy a manual! Depending on the type of headlights you have (halogen or Litronic), the city lights will either be a W5W (wedge) or an H6W bulb.
There are plenty of "white" W5W bulbs out there -- I used a pair of PIAA Super White W5W's when I had halogens. After I upgraded to Litronics my options were limited. If you want a nice match to the Litronics then get the Höen xenonmatch H6W. They've been out of stock for a while though, probably because they burn out after 4 months! If you don't mind a little yellow I recommend the Philips H6W BlueVision. They're "whiter" than the stock bulbs and last just as long or longer.
Check out http://www.ambulbs.com for the Phiips BlueVision and other bulbs.
Cheers,
.:programmatore:.
The bulb is an H6W Halogen I believe, double check your owners manual.
You wont find these at PepBoys or AutoZone and it may be easier to just go to the dealer.
Get 2 and replace both since the other one may go out soon
To replace use the supplied tool and pop your headlamp assembly out, and replace bulb
Thanks for the info. I ordred the BlueVision bulbs and will look in the manual and for this tool. The only tools I have are in the boot, so I assume it's in there with the tire changing equipment?
Yes, I should know this but I don't. Never even looked in that bag as I've never had to put my spare on.
Originally Posted by DJ 996
![manual](https://rennlist.com/forums/graemlins/rtfm.gif)
To be perfectly honest, I keep forgetting to check into what bulbs they are and thought I would simply ask here and then order them on-line. The car is at home in the garage along with the manual.... so I can't RTFM right now!
