wiper blades
wiper blades
hi all...
i recently reallised that the speeds of the wiper blades of the front windscreen of our 996 C2 are only 3....
at my 964 they were 4!!!! the 4rth one was extremelly quick so that you could drive with 120+ mph in the rain (depending on the condition of the tarmac)
in our 996 there is no 4rth scale...and of course it is impossible, (even if the tarmac is perfect ) to drive over 100 mph and normal rain....
any suggestions?
any suggestions?
i believe there are only 3 modes in the 9x6 generation
i believe its:
---push the stalk up slightly and you get one single swipe
---pull stalk down one notch and you get intermittent mode, determinned by the little **** opposite the cigertte lighter
---push stalk up once for normal
---stalk up twice for fastest mode.
i believe its:
I swear by RAIN-X. It is a surfactant that works especially well at high speeds or heavy rain - no wipers required. It is applied on clean dry glass and lasts more than a month. With less use of my wipers, the glass clarity is preserved. RAIN-X makes the water bead up and roll off. Related products are used on aircraft glass. RAIN-X glass does however need wipers at low speeds and mist. Visibility in a torrent or speeds above 75mph (120km/h) is fabulous.
emillios,
i understand what u say, that 996 efficiency is better than 964...but i found the 964's fourth scale more efficient than thw 996's 3rd at 120 mph....
Newbies Hospitality Director
Originally Posted by harris
is there any posssible way of pushing the wiper blades to perform faster?
for ex. adding more electricity to the circuit?
Apply rainx to a dry windshield and let it dry on. Also, use Bosch Micro Edge Excel blades. They work better than any blade I've ever used before, hands down.
i have used rain-x in the past
i found very annoying the fact that the rain drops "draw" straight lines on my wind screen when they try to escape....
Originally Posted by riad
I also use rain-x. I have more of a problem with the 996 wipers themselves. I think they are too light and tend to skip.
Rob
Rob
I will look into this thread's post recommendation to try Bosch's wipers. The stock wipers are not so great. Of course, it might be worth trying this Rejex surfectant also. I had not heard of the product before....
