996 Forum 1999-2005
Dealer issues programming CDE
Old Feb 12, 2025 | 03:15 PM
elnonio's Avatar
elnonio
Default Dealer issues programming CDE
So I installed a cruise control stalk and wired it on my 2004 C4S. No issues, went on long drive, plus it's turned into my daily. But of course it needed to be activated, so I dropped it off at the local Boblingen dealer yesterday.
Today, I get a call that they are having issues. They couldn't program it, and now the ignition and the immobilizer and transponder is/are giving them a hard time. They think it's due to the modern programmers they have, and have asked the main factory (a mere what, 30 minutes away?!) for an older model.
Any suggestions I may relay to them would be helpful. Or at least make me smart. That's a tall order, I know.
Old Feb 13, 2025 | 03:01 PM
elnonio's Avatar
elnonio
Update: dealer says that the issue started after they plugged in the PIWIS 4 to the car and updated the CDE and cluster, everything went haywire. Immobilizer, ignition, etc. They have asked to see if other dealers have an older PIWIS, but that they (in general) were made to send the old ones back to Porsche.
He also said that he thinks German spec cars were not able to be retrofitted with cruise control.
Anyone have any thoughts?
Old Feb 16, 2025 | 01:08 PM
Taos996's Avatar
Taos996
Interesting. Retrofitting cruise control. I'd don't see why not. Your case is easier than a 7.2. 7.2 the switch wiring goes back to the DME. In yours just to the cluster and Canbus takes it back to the DME. There is nothing behind the DME that needs to be added. They should be able to turn it on. If there is a problem, it'll throw a (non-cel) code but otherwise no issue.
Very sorry to hear they've possibly blown up your system. Very scary. I have my own PSWIS (I) I long ago started doing everything myself but sometimes, I'm lazy and just want an excuse to drive to Miami. Now I'll have to come up with something that absolutely, doesn't involve Porsche plugging in.
I hope they get all of this sorted out for you on their own phenning.
Old Feb 16, 2025 | 01:40 PM
e30rapidic's Avatar
e30rapidic
Do you have a wire going to the back of the cluster for the cruise system in pin C19? I had to add that additional wire when I put the manual cluster in after the 6 speed transmission swap.
I thought I had a photo on my phone. If you look in my transmission swap thread, you’ll see what I’m talking about.
https://rennlist.com/forums/996-foru...ith-a9635.html
Old Feb 16, 2025 | 04:38 PM
elnonio's Avatar
elnonio
No such wire. Mine is a manual. The different guides I've seen, plus the one from pelican, don't mention anything other than the 4 wires from the control stalk, 3 to the cluster and one for the brake signal.
Old Feb 26, 2025 | 07:43 AM
elnonio's Avatar
elnonio
Dealer said that the DME was coded to a different country than germany, causing the issue.
issue fixed, but the cruise control they said still can't be activated, no retrofit possible.
Old Apr 20, 2025 | 11:39 AM
elnonio's Avatar
elnonio
I finally got my hardware to use the PIWIS III and was able to code instrument panel and CDE for cruise control. Alas it still does not engage (though I now get the cruise control light to turn on briefly when the car starts). I must recognize the possibility that my wiring is not right.
Old Apr 20, 2025 | 01:22 PM
e30rapidic's Avatar
e30rapidic
go to the inputs tab and see what’s going on. Check to see if the clutch pedal and brake switch circuits are open or closed. The value will change in real time when you hit the clutch and/ or brake pedal
Old Apr 20, 2025 | 01:31 PM
elnonio's Avatar
elnonio
The brake and clutch real time indicators change correctly. Not getting anything from the cruise control stalk. Hope I wasn't sold a dud...
Old Jun 14, 2025 | 08:20 AM
elnonio's Avatar
elnonio
Issue is finally fixed. It was my tap into the B7 fuse that was deficient. I now have a cruise control that I can turn on and off, set the speed, cancel at the stalk, reduce the speed.
Yeah, I can't increase the speed (at least not smoothly like I can decrease speed) so I guess something is pinching. I will need a second wind to remove the steering wheel and all that. But since I have a 99% functional cruise, I am as happy as can be.
Old Jun 14, 2025 | 08:09 PM
Porschetech3's Avatar
Porschetech3
Good for you, glad you got it working !!!
Not much help we can be when the problem is just a faulty connection ( self induced)
Old Jun 15, 2025 | 12:25 PM
elnonio's Avatar
elnonio
Turns out the stalk is working just as it should. I'm just so used to my other car where's pushing the stalk up increases speed that I didn't realize the up movement does nothing on the 996.
All is well.
Well, except that the car decided to purge itself of so coolant on a little simple Sunday drive. Great....
Burp
Burp
Old Jun 15, 2025 | 08:00 PM
996-CAB's Avatar
996-CAB
All is well.
Burp
Burp
Like that never happened to any of us. Been systematically replacing all the hoses around the engine.
Let us know which hose it was.
Old Jul 10, 2025 | 05:22 AM
elnonio's Avatar
elnonio
Update: No hose failures. They replaced the water pump with the one I had already ordered from Pelican, changed the coolant, pressure tested. No issues. Also replaced a bunch of exhaust clamps/hardware that was badly rusted out. Winter project: clean the engine and overall underbody, and properly treat/winterize.
I happen to now be due for an oil change, gonna do that tomorrow. Provided I find no surprises there, this should be the end of this episode.
