996 Forum 1999-2005
Discontinued Ruf Wheels Question
Old Sep 26, 2024 | 10:58 AM
Beefer's Avatar
Beefer
Default Discontinued Ruf Wheels Question
I came across a set of discontinued OZ Ruf Wheels. Its a staggered set up with the front being 18×8.5″ wheels carry part number 63001001 and have a 58mm offset. The rear wheels are 19×10″ wheels bear part number R96.362.12010 and have a 66mm offset. The 18'' will fit a 996TT according to the RUF site but the 19's for the RUF is 19x11 with a 55mm offset. Will I be able to make 19x10 with 66mm offset work? I dont race, this is strictly for road driving with occasional spirited driving.
Old Sep 26, 2024 | 11:36 AM
hatchetf15's Avatar
hatchetf15
et 66 will sit flush on C2 in 11”. 15mm spacer will flush out a 10”
et 55 will poke 1/2 “ on C2
No opinion on staggering a 19 with an 18 except the 996 is rake sensitive.
Old Sep 26, 2024 | 11:40 AM
wdb's Avatar
wdb
You don't say what body you have -- narrow body or wide. 66mm offset is going to be 996 narrow body fitment, perhaps also an earlier aircooled car. (Factory 996 C2 18" wheels are 65mm offset.)
Old Sep 26, 2024 | 01:45 PM
GC996's Avatar
GC996
Beefer, not certain why you would want to use a staggered wheel setup on a 996 regardless of the manufacturer. The seller of the wheels probably just figured it out.
Imho, I would stick with 18s all the way around. 8s and 10s or 8.5s and 11. The 996 is an incredibly handling car if you stay within the spec ranges. But you can really screw it up when you go outside the range.
Old Sep 26, 2024 | 02:00 PM
Beefer's Avatar
Beefer
I have a wide body 996 turbo..you're spot on, they came off a C2 but claims that previous owner had it on a 996 wide body TT
Old Sep 26, 2024 | 02:12 PM
GC996's Avatar
GC996
The 996 Turbo guys can probably provide good ideas on wheel/tire sizes that work best with the AWD system and computer on and off the track.
Old Sep 26, 2024 | 02:24 PM
Beefer's Avatar
Beefer
the previous owner had 235/40 R18 on the front and 285/30 R19 on the back...almost perfect rolling diameters according to tiresize.com
Old Sep 26, 2024 | 03:27 PM
GC996's Avatar
GC996
I give you a bad analogy. Using that configuration, the 996 Turbo is a very powerful car with the right size equipment up front but very long skinny legs in the rear with small shoes.
