Has anybody used UV Dye to find leak on coolant? Is it safe?
Hallo guys.
I wanted to know if somebody has experience with this and if it is safe. Also if they ourgued the coolant afterwards or kept it.
Thanks a lot.
Thanks a lot.
nemex12 (Yesterday)
The following 2 users liked this post by 2002C2:
hardtailer (Yesterday),
nemex12 (Yesterday)
I have heard that. I will try tonight to check if I can see it glow with a UV light I have. I may save a couple of bucks if it is. Also I don´t know if the water mixture makes it lose fluorescence because I have topped it up with distilled water :/
Pressure test should show the leak unless its internal in engine/oil cooler/aos/heater core. Can you keep a constant 18psi pressure test on the cooling system. How fast does it lose pressure..? If keeping a constant low pressure on system, should show a drip somewhere... eventually..?
Leak dye will only work if you can see the leak and its dripping out the dye. Most of the time if you can see the dye you could see the colored coolant. Dye is last resort, if at all,,, imo.
Its like all the snake oil engine detergent additives and fuel additives etc that say they are good for your engine and should be added to every fuel up/oil change, when they definitely arent and shouldnt be.
