996 Forum 1999-2005
Rear camber adjustment
Old 08-27-2024, 08:44 PM
2002C2
2002C2's Avatar
Default Rear camber adjustment
Call this don’t try this at home. Tried to make a subtle tweak to improve tire wear a little. Ended up with a crooked steering wheel, and psm and abs warning lights. After many many attempts, I finally got it back to normal. Now I just need to visit a professional to get it absolutely right. Below are the crude tools and some advanced geometry that actually worked to get it back to normal. The wood block was a key piece.
Old 08-28-2024, 10:47 AM
wdb
wdb's Avatar
Received 1,265 Likes on 694 Posts
https://www.fcpeuro.com/blog/at-home...align-your-car
Old 08-28-2024, 06:06 PM
hardtailer
hardtailer's Avatar
There is a google spread sheet document floating around on here, I believe, that calculates how many degrees each eccentric bolt must be turned to achieve the specified settings after filling out the spread sheet with the current values of toe, camber, track width etc.
It takes away the iterations normally inevitable to achieve the target values.
Unfortunately I cannot find it...
Found it!
https://docs.google.com/spreadsheets/d/1J3rnpmtFgx0jZPqTDytrg_unx2dL7PFKhA0IRWtLjXA/edit?usp=drivesdk
Old 08-28-2024, 09:25 PM
2002C2
2002C2's Avatar
Found it!
https://docs.google.com/spreadsheets...t?usp=drivesdk
I saw that one too. Thanks. Didn’t have much success with it. It was trial and error with a mm ruler. I think I got lucky. Drove to work today with no issues. Very dumb on my part. Lesson learned.
Old 08-28-2024, 09:28 PM
2002C2
2002C2's Avatar
this is a good one. Don’t know how I missed it. I buy stuff there all the time. Thanks
Old 08-29-2024, 12:02 AM
hbdunn
hbdunn's Avatar
This is also useful
Digital Angle Finder Magnetic...
Amazon Amazon
Old 08-29-2024, 03:41 PM
circuit.heart
circuit.heart's Avatar
Found it!
Don't think it really works like that, eccentric bolts by nature adjust a linear position by sin(theta) or cos(theta) depending on which direction you're looking at it. I've learned to just set the car up on level tire stands with the gauges and toe plates all connected, then get underneath and ask a friend to read out the numbers as I fiddle with the eccentric.
Then good luck tightening the nut back down without the eccentric moving, not sure why but my C2's rear subframe must be slippery or something.
Old 08-29-2024, 04:46 PM
De Jeeper
De Jeeper's Avatar
Received 3,478 Likes on 1,831 Posts
Its not your subframe...its a poor design and should not be used in a performance car.
Old Yesterday, 02:45 PM
2002C2
2002C2's Avatar
For me it was a good lesson :
1) don’t mess with it
2) if you mess with it, it can cause all sorts of weird results
if my abs and psm lights were on, rear camber would not be on top of the list to check.
Jnelso (Today)
Old Today, 08:26 AM
Viper1000
Viper1000's Avatar
lol I too am in the same boat at the moment :P(.
Old Today, 11:05 AM
2002C2
2002C2's Avatar
surprisingly, the bush fix tools actually worked. That and a little luck I’m sure.
Old Today, 07:34 PM
c didy
c didy's Avatar
Good work getting it back together. Sounds confusing . How did adjusting rear camber give a crooked steering wheel?
Old Today, 08:17 PM
hbdunn
hbdunn's Avatar
It changes the rear toe.
Quick Reply: Rear camber adjustment
