A few mods for my wife's 964 Cab which she doesn't even know about yet! :D
R.I.P.
Lifetime Member
Lifetime Member
It's a lot different and more subtle putting my favorite Arctic Silver mods on Cindy's 91 Black 964 C2 Cab, but I'm managing a few.
1. Silver hood crest, of course
2. Steering wheel crest (harder to find a small one to fit a 964
3. Gas Cap pull
4. Ignition Surround
5. *****
6. Swap black engine Carrera badge for a silver one.
7. Instrument rings (of course)
8. New SS exhaust pipe (no pic)
I know, I know, I need the headlight switch
Do you think I should go the aluminum pedal bit or is that too, well, macho for a woman?? Any other suggestions???? You know that she doesn't know she's getting this yet...total surprise
3. Gas Cap pull
5. *****
Super Moderator
Needs More Cowbell
Needs More Cowbell
Pedals are probably more a function of feel than looks, but on a tip a set of Ruf pedals would look nice (don't know if Ruf makes pedal sets for tips).
As for other mod suggestions, I would 'finish off' the dash by installing the Euro rear center reflector (integrated fog lights) and the dash switch in the factory (unused) location.
Did it in my RSA and was very happy with the results. Bought it (complete kit) from Schatzmotorsport.com in CA.
The European light bridge (simple plug in replacement) which allows for the fog lights to come on with parking lights only is also a nice addition.
On a black car, I would also change the side markers/reflectors from amber to clear, looks much nicer on dark colored 964 IMHO.
I would also change the H5's to H4's....a huge difference at night. You can get the whole kit from Vertex Auto (either chrome rings or primered/paintable ones)....Eric at bumperplugs painted mine midnight blue metallic on the RSA...the man is a wizard at paint matching.
Best of luck with the car, I'm sure she will love it.
Regards,
Regards,
R.I.P.
Lifetime Member
Lifetime Member
Itc, I appreciate your thoughtful reply. RUF does make alum pedal covers for a Tip. I have them on my 996. If the interior was black I wouldn't hesitate, but it's beige so actually the black pedals look more compatible with the other black trim.
Headlights are a god idea..
Are the yellow reflectors easy to change on a 964? Do you have to remove the bumper or is it a simple swap?
I thought about the vacant space on the dash but I assumed the wiring necessary for the rear fogs in the reflector would be a complicated procedure. Do you any DIY help on that one?
Thanks again for your help.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Don,
The side markers/turn signal only require a philips screwdriver, no need to remove the bumper! Takes about 5 minutes total. See item A in the link below:
http://www.schatzmotorsport.com/Merc...egory_Code=850
(I did not do item B, which replaces the small black bumperette) There have been posts on installing this item over on the 964 forum however.
As for the Euro rear center reflector (w/ integrated fogs), all 964's had the wiring harness installed. The connector is behind the dash and the connectors for the rear fogs are already there in the back as well. It's simply a matter of removing the radio, drilling out the '4th' hole in the dash and installing the switch. Replacing the rear center reflector is simple, only a phillips screwdriver.
The light bridge merely plugs into the fuse box in place of K22(? I think). I like being able to run the fog lights independent of the headlights and keep them on with highbeams. Takes 2 minutes.
