Help! 991 Steering Wheel Adaptor on 996
Hi guys I bought a 991 spline adaptor for my 996 via spacershop. Everything is working nicely except I can’t figure out how to get the horn working. It came with a red jumper but where does the horn plug into? Updated with photos
Looks like you have it wired correctly, The horm wire is just a single wire that grounds to the steering shaft/frame when activated.
You may have a faulty horn relay/dual horns/fuse ... Just ground the horn wire and the horn should sound..
BTW :: Very nice upgrade !! I love the 991 paddle shifter steering wheels on the 996 Tip cars...the look and feel are exceptional. !!
Hello friends
I also need help,I have 996.2 with tiptronic and I want to install original 991.2 steering with paddles shifters
i have search around last month but no write up for this conversion (tiptronic buttons to paddles shifters 991)
i would appreciate if someone could help really
thanks in advance
thanks in advance
That looks amazing! @the netrox check this out: https://p-car.com/diy/steeringradio/ Sourced from: https://www.reddit.com/r/996/comment...teering_wheel/
thanks for you help🙏 but in that link they not write for enabling paddles
But I want only to work paddle shifters from 991.2 steering wheel in 996.
Current 996 wheel is with tiptronic
(so no multifunction buttons on both….)
The wiring for the Tip switches/paddles is very simple...
The control only uses 3 wires , (1) a common wire (2) an upshift wire + ( 3) a downshift wire -
the paddle shifters have 2 wires each ,
the left paddle gets a common and the downshift (-) wire ( note : it doesn't matter the polarity of the wires)
the right paddle gets a common and the upshift wire (+) ( note : it doesn't matter the polarity of the wires)
That's it !! .. If you need the wire colours refer to the instructions or to a wiring diagram...
thank you so much,I appreciate your help 🙏
Hello to all members
My client had accident with his 996 so not able to make this amazing retrofit
So I am selling a Porsche 911.2 turbo s new alcantara original steering wheel with airbag + extender adapter to fit in all 996
Ready for plug and play installation
send me pm if you are interested to give you all data
I could not put advert in marketplace of forum
John
John
curious if you'd be willing to provide a measurement betweem the turn signal stalks and the wheel? Are the extremely far back from the newer wheel?
