If u go stainless then make sure u antisieze or lube the threads or it may gule and lock up.
What is alternative to stainless?
The nut i think is welded on so hopefully can find right threading.
Thanks for all the replies btw, i know this is a minor part, but after doing water pump, thermostat, and some new water pipes, a kicker to have this piece be the hold up completion
Oh and the rubber speed nut that holds the air pump shredded too, so then had to remove the entire bumper
I had a similar issue with one of those speed nuts on the air pump when replacing my coolant tank. I also replaced my water pump and thermostat only to have my engine get torn down 5 months later due to something else. It also turned out that I accidentally bought the water pump for the turbo. The car didn't go any faster.
Dang i hope the speed nut wasn't the precursor! lol
That bolt is an M8x1.25 and should be available at any good hardware store. Stainless steel will be fine with the regular steel nut that's on the clamp. You could put some anti-seize on it although that does not help much with exhaust bolts.
Yup matched the threading at home depot and managed to find ONE M8x1.25 40mm cap screw , in a totally wrong section. Zinc plated.
EDIT::: Neither old or new would go in, but managed to force the "old" in, and the new in the other side. holy crap that was a study in patience.
Sadly it doesn't fit Looks almost identical.
It will however go in the other nut, so something is stripped in this one nut. Man it's always something !
The OEM bolt won't go in either, and threading from back side it's really stiff. Hoping can rethrrad the bolt, otherwise arg. Need this all done before tomorrow morning's 996 group drive.
Here is the solution. Pull that clamp off.
order a new one.
go to AutoZone and get one of these and maybe a 2 inch.
temporarily fit until the new one comes.
or put a smaller bolt and nut temporarily through the exhaust clamp you have.
When I was doing my coil packs, I removed the mufflers. I did not want to put the old bolts for the double connectors that hold the mufflers to the cats back. I ended up using Belmetric to get some SS bolts to replace and they worked great. They had a great selection of just about every kind of metric fastener you can imagine.
A set of metric taps and dies is standard equipment for Porsche, BMWs, Audi, Toyota, Honda owners who work on their cars. You could have chased the thread with an M8x1.25 tap because clearly the clamp threads are messed up.
^^ This. I bought the complete SAE/metric husky set from Home Depot on sale (~$100). Guaranteed for life and a life saver when we rebuilt the MG.
