996 Forum 1999-2005
Part no. or bolt spec for exhaust clamp bolt that snapped?
Old 04-25-2024 | 08:31 PM
Ben8jam's Avatar
Ben8jam
Default Part no. or bolt spec for exhaust clamp bolt that snapped?
I cannot for the life of me find which bolt I need for the clamps that hold the exhaust support to the exhaust itself. In trying to remove one it snapped the bolt in half. And if I can't get one at Porsche tomorrow I will happily use one from Ace or Lowe's in the time being but I cannot figure out what size bolt it is to be specific.
Old 04-25-2024 | 09:03 PM
Patunia's Avatar
Patunia
If you an see the face of the bolt it may have markings,,,,I have no other suggestions 😕
Old 04-25-2024 | 09:12 PM
ssherman68's Avatar
ssherman68
I recently bought a book from LN/Jake Raby that has the bolts and torque specs for the 996. Let me see if it's in there when I get home.
Old 04-25-2024 | 10:33 PM
ssherman68's Avatar
ssherman68
Unfortunately the book shoes the clamp but doesn’t show those bolts:
Old 04-26-2024 | 12:35 AM
dporto's Avatar
dporto
It looks like it’s #14 in the drawing
Old 04-26-2024 | 01:23 AM
Ben8jam's Avatar
Ben8jam
no those are the bolts that hold the mounting bracket on. i need the bolt that goes through those two floating circular clamps right next to the #14
Old 04-26-2024 | 01:32 AM
hbdunn's Avatar
hbdunn
It’s an m8 x 45mm bolt. The problem is you snapped it off in the nut and it’s gonna be pretty hard to get it out of there. I would cut the nut off and just go buy a bolt and nut to secure it with.
Also a standard u-bolt exhaust clamp would work until you get a new stock one.
New clamp is relatively inexpensive 7-13 bucks.
Ben8jam (04-26-2024)
Old 04-26-2024 | 12:31 PM
Ben8jam's Avatar
Ben8jam
Thank you. I'm really hoping i can bake the broken bolt piece out of the nut. I'm not sure i can bend that clamp wide enough to get it off the exhaust pipe. And I sure as heck don't want to have to remove the entire pipe. I only removed it to remove the engine brace.
I just replaced my water pump and thermostat, and this bolt was the hardest part (funnily enough).
Old 04-26-2024 | 01:16 PM
DBJoe996's Avatar
DBJoe996
Maybe this diagram will help - http://www.autoatlanta.com/porsche-p...section=202-00
Old 04-26-2024 | 01:55 PM
Ben8jam's Avatar
Ben8jam
Originally Posted by DBJoe996
Thank you, i don't know why I have a hard time navigating atlantas site to find those diagrams.
Its clamp #13. Looks like bolt comes with it.
Is there a trick to getting tjay clamp open wide enough to slip off exhaust pipe?
Old 04-26-2024 | 03:08 PM
Fracture's Avatar
Fracture
something wonky here - that does not look to be a Porsche bracket, they use 2 bolts
and what is that flat bar doing there ?
Old 04-26-2024 | 04:44 PM
Ben8jam's Avatar
Ben8jam
It's all oem. Refer to the diagrams above. The single C clamp uses one bolt. Flat bar is bracket that secured exhaust to engine. The clamps in your pic look after market.
Old 04-26-2024 | 04:49 PM
Ben8jam's Avatar
Ben8jam
It’s an m8 x 45mm bolt. The problem is you snapped it off in the nut and it’s gonna be pretty hard to get it out of there. I would cut the nut off and just go buy a bolt and nut to secure it with. i
Dremmeled the sides down flat. Heated it up a couple times. And with some grunt... got it free!
dporto (04-27-2024)
Old 04-26-2024 | 06:09 PM
Fracture's Avatar
Fracture
I see, ....it's MK1
Old 04-26-2024 | 06:18 PM
hbdunn's Avatar
hbdunn
I see, ....it's MK1
Same for a mkII. The clamps you showed are for connecting the cat to the muffler and tips to the muffler. These clamps secure the pipe to the engine mounted support.
Quick Reply: Part no. or bolt spec for exhaust clamp bolt that snapped?
