Exhaust Rattle
Exhaust Rattle
Have this weird rattle coming from the left exhaust pipe...if step on it a little bit it'll stop.....its like the exhaust is rattling up against something on that left side...
I had the same issue. If the tip isn't loose, check the bracket weld on the pipe just before the tip. My weld had broken lose. Since it's stainless steel, I didn't have the welder to handle stainless, so used a stainless hose clamp tightened over the tang that had broken loose from the pipe and it has made a tight repair, holding well since.
Cat’s
I ended up needing to replace both.
Jjcrawdad (10-20-2023)
The following 2 users liked this post by 996C438:
85eurocarrera (10-21-2023),
Jjcrawdad (10-21-2023)
