996 Forum 1999-2005
VAG 1924
Old 04-04-2023 | 08:54 PM
Argeo's Avatar
Argeo
Default VAG 1924
Anyone know a substitute for the VAG for getting fluid into my tiptronic?
Argeo's Avatar
Argeo
Old 04-04-2023 | 11:49 PM
SoCal911t's Avatar
SoCal911t
I don't know anything about the VAG unit but I modified a $10.00 Ace Hardware garden sprayer to do what it seems like the VAG does.
I cut the tip/ mister part off and then used a heat gun to bend the plastic tube into an elbow at the end. It works great for diffs, transmissions and the transfer case on the Cayenne.
The following 3 users liked this post by SoCal911t:
dporto (04-05-2023), Fracture (04-05-2023), Krulm (04-05-2023)
Old 04-05-2023 | 12:04 AM
Argeo's Avatar
Argeo
Not sure that will work for my Application. Not sure it would fit in the hole. Problem is I am doing at a friends house and hour and a half away. To drive, take car apart (Boxster) and not be able to get in hole would be a 1st world disaster.
Old 04-05-2023 | 12:18 AM
SoCal911t's Avatar
SoCal911t
I give up.
Argeo (04-05-2023)
Old 04-05-2023 | 12:26 AM
Argeo's Avatar
Argeo
Thanks for trying.
Old 04-05-2023 | 12:53 AM
Porschetech3's Avatar
Porschetech3
I built one out of a bug sprayer like SoCal did for the Porsche Dealer I retired from except I used a steel brake line for the nozzle. I notched the brake line then bent it past the 90* position then soldered it up...( shaped it like the VAG one)... They are still using it...
It does have to be small on the end to fit in the hole, I had to cut mine down to fit at first..
The VAG one we had ( on the AUDI side) is a gravity feed but the open/close valve has big ports and flows pretty fast...so even with 20-30 psi the bug sprayer devise is a bit slower but all the Audi guys would come across the shop to borrow the one I built instead of using the VAG one.....
Old 04-05-2023 | 08:56 AM
996C438's Avatar
996C438
The garden sprayer shown above . If you need the tip to be smaller slide a piece of metal tubing inside . A little JB Weld and some shrink sleeving and you are done .
Old 04-05-2023 | 09:11 AM
cdk4219's Avatar
cdk4219
I use a marine out drive hand pump, the plastic ones will thread into the drain plug. Lots more pumping than the sprayer though
Old 04-05-2023 | 09:35 AM
Argeo's Avatar
Argeo
Me, not you guys. I overthink everything. How about r
this?
Old 04-05-2023 | 11:15 AM
Joey996's Avatar
Joey996
this?
I bought that and it worked perfect filling my Tip. No issues at all.
Joey
Old 04-05-2023 | 11:55 AM
Argeo's Avatar
Argeo
Perfect, thanks Joey.
Old 04-05-2023 | 05:45 PM
Porschetech3
That one is perfect ( it wasn't available 2 decades ago).. Just needs a Schrader Valve on it also to pressurize with shop air , then it would be absolutely perfect with all the different nozzles..
Argeo (04-05-2023)
Old 04-05-2023 | 06:06 PM
Argeo's Avatar
Argeo
Thanks PorscheTech. Could you provide any insight on removing the diagonal brackets and brace on a 986 Boxster to get At tiptronic tranny. I’m sure I can take apart, but does it go back together easy. Suggestions?
Thanks.
Old 04-05-2023 | 06:43 PM
Porschetech3
Yes it comes apart really easily but sometimes the studs spread out a bit and makes going back together a little harder...The big flat plate #6 actually holds the left and right suspension together...If the studs don't line up I have just used a ratchet strap between both rear tires to pull them together enough for the studs to line up....Once bolted together it is quite sturdy...
Removing #1 #6 #7 is very quick and easy....Reinstalling usually goes without a hitch but sometimes the ratchet strap trick is necessary...
Argeo (04-05-2023)
Quick Reply: VAG 1924
