View Poll Results: How to lift the rear for a oil change fastest / cheapest?
Lift the car with two jacks after which use chock and axle stands
4
25.00%
Get race ramps (:-( expensive no other altern. for wide tires)
7
43.75%
Build your own from wood
5
31.25%
Voters: 16. You may not vote on this poll
Race Ramps or other pragmatic solution for oil change?
#62
I don't jack up the car or use ramps for an oil change. I have a low profile oil pan that just slides right under and can hold a little over ten quarts. For safer and easy. Car is on stock suspension. I also have the spin on oil filter adapter. I just reach in with my hand to loosen.
#64
My solution: A couple wood blocks under one tire (yes, I bought new PS4s!), a $6 frypan splatter screen and whatever trash oil collector I had lying around. The splatter screen ensures there's zero mess. Could probably get it done without the wood but it makes it a bit more comfy taking care of the oil tank.
#65
Frypan splatter screen - genius. You have inspired me!
