996 Forum 1999-2005
View Poll Results: How to lift the rear for a oil change fastest / cheapest?
Lift the car with two jacks after which use chock and axle stands
4
25.00%
Get race ramps (:-( expensive no other altern. for wide tires)
7
43.75%
Build your own from wood
5
31.25%
Voters: 16. You may not vote on this poll
Race Ramps or other pragmatic solution for oil change?
Old 03-14-2023 | 11:28 AM
  #46
shft22's Avatar
shft22
Been very happy with EZcarlift, no hydraulics or hoses to deal with. all is needed is a drill. Only draw back in my case, because my car is very low I do need to drive it on top of 2x4's before I can slide the carlift under it. They sell a drive up option but haven't looked at it in detail
The following 2 users liked this post by shft22:
dporto (03-16-2023), wdb (03-14-2023)
Old 03-14-2023 | 12:50 PM
  #47
wdb's Avatar
wdb
My son-in-law has one of those. For the number of times he uses a lift it is a great option. Folks should be aware that the two pieces are connected, so there will be bars across the underside of the car when it's in the air.
Old 03-15-2023 | 03:42 PM
  #48
shft22's Avatar
shft22
Correct the two pieces are connected, but the rear lift cross member can be taken off once the car is in the air for easy access to the transmission and rear of the car
wdb (03-15-2023)
Old 03-16-2023 | 09:00 PM
  #49
pdxmotorhead's Avatar
pdxmotorhead
I change my oil on the ground no issues.. And I DONT fit under the car, only tricky bit is the drain pan I use is a 12 quart, fits under car but when all the oil is drained you do have to pull it out slow and steady.
I use a old dollar tree bread pan under the oil filter.
Old 03-16-2023 | 10:53 PM
  #50
dporto's Avatar
dporto
I've got a EZ Car Lift as well, but I don't generally use it for oil changes only (if I have other stuff I need to get done under there sure...). I've had it for about 3 1/2 years and its been great. I use wood ramps as well to get the car high enough to roll the EZ lift under.
Old 03-16-2023 | 11:32 PM
  #51
4Driver4's Avatar
4Driver4
This year my garage was jammed with other cars, so I resorted to a couple of 4x4's
wdb (03-17-2023)
Old 03-17-2023 | 02:08 PM
  #52
pdxmotorhead
If you drain the car wen not level, then level the car and drain it, the amount of oil you get after its level and allowed to drain is fairly impressive. YMMV...
Old 03-17-2023 | 09:25 PM
  #53
JustinReinke8's Avatar
JustinReinke8
QuickJacks here too. First oil change for the new engine. These things are fantastic. Need a 5 gallon bucket for the oil it is so high. Ignore the junky garage, it is a work in progress.
Old 03-18-2023 | 02:35 PM
  #54
Formerly996fried's Avatar
Formerly996fried
From: Deep in the woods near PA border in People's Dystopia Republic of New Jersey
I did a variety of methods to jack up the car, but finally purchased the quick jacks......and it also become one of those "while it's jacked up"..
Old 03-18-2023 | 05:23 PM
  #55
dporto's Avatar
dporto
What wing/spoiler do you have on there? Is it Getty ERS ?
Old 03-18-2023 | 07:04 PM
  #56
wdb's Avatar
wdb
And the wheels...
Old 03-19-2023 | 04:24 AM
  #57
JustinReinke8
It is, good eye.
Old 03-19-2023 | 04:25 AM
  #58
JustinReinke8
And the wheels...
Fuchs
Old 03-19-2023 | 11:15 AM
  #59
dporto's Avatar
dporto
It is, good eye.
Nice! Any chance of a few more pics from different angles? Thx
Old 03-19-2023 | 11:29 AM
  #60
DBJoe996's Avatar
DBJoe996
this thread is winner winner chicken dinner...59 posts on how to do an oil change...sheesh
