996 Forum 1999-2005
Refinishing wheels
Old May 13, 2022 | 01:35 PM
robinbabu's Avatar
robinbabu
3rd Gear
Default Refinishing wheels
Does anyone know if a wheel like this could be refinished? If so, any idea on how much this should cost? New to the forum, recently bought a 996 '05 c4s cab! Thanks for the help
Old May 13, 2022 | 01:41 PM
TheChunkNorris's Avatar
TheChunkNorris
I've seen worse get refinished and most places down by me around 150-175.00 per wheel.
Old May 13, 2022 | 01:57 PM
996C438's Avatar
996C438
Serious question- can you use sandpaper and a spray paint can ? Get the tire/s removed and clean the wheels . Use sandpaper to remove and feather the scratches . Clean the wheels again . If all looks and feels good then hit them with spray paint of choice .
Different story if you want them powder coated or Cerakote . Those finishes are generally considered pro finishes . They will media blast and then coat . The plus is these finishes are very tough . Downside is they are not easily touched up like spray paint .
Old May 13, 2022 | 03:42 PM
DBJoe996's Avatar
DBJoe996
There are mobile guys that will refinish the wheel(s) for you right in your driveway. Check around.
Old May 13, 2022 | 03:57 PM
TheChunkNorris
They'll bead blast and even the scratches, then paint and clear coat, most of the time they'll check for bends but not always. I personally wouldn't spray paint wheels especially on our cars that release so much brake dust.
Old May 14, 2022 | 10:23 AM
Corso's Avatar
Corso
Damn....I wish I had your guy up here in CT. I just paid $275 a wheel to have just the lips (wheel rim) refinished on 2 of my Sport Designs. They didn't even touch the wheel. And the flaws were very minor, but I'm a lunatic so I had to have it taken care of.
Old May 14, 2022 | 11:11 AM
TheChunkNorris
Oh man yeah multi-piece work is just as expensive, luckily the OP has regular wheels so that job is so much easier. I curbed a set of flow formed Vorsteiners on my VW and luckily there was no barrel damage, they'll true wheels as well and that gets a little pricey for a set of 4.
Old May 14, 2022 | 12:26 PM
motoo344's Avatar
motoo344
Easy, no more than $100-$200 bucks. Dealers usually have someone that does it or a powder coater would be a good bet. I think my wheels were around $175ish to coat and the included new tire mounting and center caps.
Old May 14, 2022 | 11:05 PM
Argeo's Avatar
Argeo
200 per wheel in Mass. stripped, sanded, filled, straightened, paint and clear.
