Bad water pump?
Bad water pump?
Hi all, my 2002 996.2 with 42k miles leaked some coolant which looks to be coming from the pump. Based on my visual assessment and what I read in the forum, I am 95% it is the pump. Looking for that extra bit of confirmation before I order the new pump/thermostat.
Thanks in advance!!!
Frank
Frank
TexSquirrel (04-25-2022)
Francisco, check your service records. If your water pump has never been replaced, it would make sense to do it plus the rubber hoses and plastic bits associated with it that will decay after 20 years. The waterpump is a part that if it goes, you run the risk of hundreds of plastic pieces floating around that can grenade your engine. It's cheap enough and easy enough to replace.
