996 Forum 1999-2005
Starting up after winter storage
Old 03-02-2022 | 01:51 PM
davidpg's Avatar
davidpg
Originally Posted by Joel987
Last spring I set the air pressure in the tires, disconnected the battery tender, placed the rubber cover over the tender wire harness that is permanently attached to the battery, and started the car. If fired up as if I drove it the day before, not 4 months before. Oil pressure came up immediately. I took the car out of the garage and went for a drive. The oil was fresh, as was the filter, so no need to drain 8 quarts of oil out just because it sat for a few months.
This spring I will do the exact same procedure. The 996 paranoia has gotten to all of us!
Agreed. I will do the same with my 996 (and C230 coupe and 323i and Scirocco) though I prefer to do my oil change in the spring AFTER hibernation. I've always done this...pop the batteries in, inflate tires, start and go fill with fresh gas. Then drive like I didn't just go through 6 months of winter hell.
And thanks for reminding me I have to buy 25 litres of oil for all the spring oil changes due....
Formerly996fried (03-02-2022)
Quick Reply: Starting up after winter storage
