‘00 C2 only one camshaft sensor from factory
Question to the specialists out there: The ‘00 C2 has only one camshaft sensor. If I use the durametric I get values from one bank the other ist 0. What will happen if I install the second sensor? (I don’t think Porsche use a wiring harness without the connector, hopefully) the reason why I want to have two sensor is to measure the camshaft deviation on both banks…
To run two sensors you would need to install the sensors/wiring and also Program the DME to USA -LEV ( Low Emissions Vehicle ) . Also would probably need SAI , and Cats, 4 02 sensors ...
I don't think the conversion would be worth it.....I would just stay ROW...
wyovino (02-05-2022)
