FINALLY Dropping The Engine
Yogibara (11-17-2021)
#32
1) It’s a “copy cat product” - this is not to say it doesn’t or can’t work. Also, it looks like they’ve done quite a bit of updating since I researched them before I did my IMSB.
2) taking the oil from the oil port on the head doesn’t seem ideal to me for a couple reasons (filtering, oil pressure).
I could go on, but I’ve already spent more time than it’s worth to argue this point. I still recommend using LNE retrofit or The IMSSolution as they are the best most developed products available.
#33
Ok, I won’t tell you “it’s what the vendor says” (that would be a stupid argument - in fact, it’s stupid that you even suggested it…). Parroting? No sir… I did quite a bit of research on all the products available when I was getting ready to change my imsb (this was around 2016 after I had owned my car for 2-2 1/2 years). While they were a little more expensive than the others that were around at the time, FSI/LN Engineering clearly had the best/ most developed product with the most backing data to prove any claims they made. Not so with many of the others. Two points…
DSC800 (11-25-2021)
#34
My point was that we should respect other's decisions on what they think is best for their cars. I've seen in the past few days you argue or make comments that are unnecessary to three different people about what they have chosen to use, I don't understand what you gain by that?
#35
dporto (11-17-2021)
#36
I have no doubt they're a superior product and I value your input. For me, it would be like putting lipstick on a pig. If my C2 had half the mileage and half the issues I wouldn't even think twice. Now if you told me that the resale value would offset the cost then I'd be dumb not to invest in it.
#37
#38
#39
BINGO!
dporto (11-18-2021)
#41
Believe me, I would if I could. They’re sold out in my surrounding area and even the stores that claim to have it, don’t. So my second option was this lift. It’ll work fine.
#42
Can you point me to where this is stated? I've looked at the ims solution very closely before having the retrofit done and have not seen such claim not have I heard of anyone transferring their solution from one motor to another.
#43
#44
The motor in my 02 C2 was rebuilt prior to me buying it and reused the IMS Solution, which was installed several years earlier to when the head developed a crack under one of the valve guides. Both top and bottom end were rebuilt. So at least in the case of my car the IMS Solution was reusable.
plpete84 (11-18-2021)
