Guess what my next upgrade will be! Updated litronic headlights!
#151
I just found this most excellent thread, after starting to research the Retrofit Labs kit after seeing it on Jalopnik. I have a bunch of questions that I haven't been able to get answered, so maybe someone here can help.
For assembling the bracket with the screw in spacers, how tight does everything need to be so things don't vibrate loose? Or does anyone use blue Locktite to keep things together? I'm guessing the kit doesn't include any torque settings for any fasteners
Since the original Litronics high beam is halogen and the control unit tilts the HID ow beam up to fill in lighting, and the RFL kit comes with a bi-xenon projector, does the tilt-up need to be disabled, since tilting up the xenon projector seems like it would make the light output too high? Or am I overthinking things and should just plug it together as provided by RFL and enjoy more light?
Is the reflector coating on the new projector more durable, like maybe put on with a PVD process? Or will these deteriorate over time like the originals?
Did anyone get the parking lights with the kit? I just noticed one of my original bulbs is burned out. Are the RFL LEDs better than what I'd get on Amazon?
And, does RFL do a black Friday special or anything, and I should wait until later this month?
#152
geoff w (11-02-2023)
geoff w (11-03-2023)
#157
#158
Just another reminder that I stock all 996 RFL kits right here in Denver!
www.retrofitlab.us
www.retrofitlab.us
#159
You will also have to pay duties when you teceive the kit as the projectors are made in China and carry a 28% import duty.
geoff w (11-06-2023)
#161
I just installed these on my 986 (had the factory Litronics) with new bulbs. Huge upgrade in lighting performance. However, I'm running into an issue where the passenger headlight flickers on an off and I get a few random error lights on the dash. Did anyone have to use any resistors or code eliminators. I haven't had a chance to swap out the passenger bulb yet. Thanks!
geoff w (01-19-2024)
#162
How long did it take you for both sides? Did you have any resource besides the video? Any lessons learned or valuable tips? I've had the kit sitting in my living room for months now, but haven't gotten around to doing it yet. Your post motives me
#163
I'd say it took less than two hours. I just used the video. It was pretty straight forward. I used a tiny bit of RTV on the 2 red rubber bushings so they wouldn't fall out when installing the new projector housing.
The following 2 users liked this post by Grateful:
geoff w (01-20-2024),
Murphey Parker (01-20-2024)
#164
#165
Definitely could be the problem, especially if the enclosures are the first run Bosch with the soy based wiring. Awful stuff doesn't hold up over from heat/cold cycles. It could also be a the main connector not seating properly with the car. I recommend applying some dielectric grease grease on both the male and female connectors before mounting.
