996 Forum 1999-2005
Sudden rough running engine
Old Oct 24, 2021 | 12:39 PM
Myazel's Avatar
Myazel
Default Sudden rough running engine
So I was out driving the car and had been in a slow construction zone for a 4-5 miles and was coming up to a stop at about 30 mph and slipped the car out of gear to coast up to the stop and the engine diedI rolled to the stop sign and restarted the car which was suddenly running very ruff. Trailers the car home and checked error codes. I had a 491 which I had for a while and misfire codes on all six cylinders. I tracked down a broken vacuum line and repaired that but the car still ran ruff when restarted. When ran for 4-5 minutes sitting in the shop there was a noticeable lack of heat on the bank 1-3 tailpipe. Car is an 03 Targa with 75,000 miles that I did a Solution on four years ago along with a water pump and various other Maintenance items, had the sump off and the engine was very clean inside and I have a lot of records with the car as I bought off of an 82 year old man that took good care of things. Car shows no revs in zone 2 and its average speed when I bought it was 27mph. I have ordered new coils and plugs for the car as the records I have show that when the 60,000 mile service was done the plugs were not replaced and remains noted on following receipts. AOS was changed by Porsche dealer at 62,000. Any ideas or thoughts would be appreciated as I wait for the coils and plugs to show up. I placed my durametric on the car today and got the following readings;
camshaft position 1 deviation -4.06
camshaft position 2 deviation 3.83
rough running cyl. 1 3.3
“. “. “. 6 -15.8
“. “. “. 2 3.7
“. “. “. 4. 2.8
“. “. “. 3. 29.7
“. “. “. 5. -20.1
actual angle for inlet cam bank1 .30
“. “. “. “. “. “. 2 -5.13
only fault codes were misfires on all 6 cylinders, I then erased everything and restarted the engine and ran it 1000-3000rpm for about 3-4 minutes, it showed fault codes, misfires on 1, 3, 2 and 4. Cam showed;
camshaft position 1 deviation -3.64
camshaft position 2 deviation 3.05
Old Oct 24, 2021 | 01:05 PM
Mike Murphy's Avatar
Mike Murphy
I can tell you the cam deviation is out of spec. That might not be the exact reason you have codes, but you will want to address that sooner than later.
Old Oct 24, 2021 | 03:18 PM
yelcab's Avatar
yelcab
I thought spec is 6 degrees ...?
You need to do a smoke test on the intake side to see where the other vacuum leak is.
Old Oct 24, 2021 | 03:27 PM
De Jeeper's Avatar
De Jeeper
A difference of 6* beteeen banks is also an issue. The positive cam reading is suspect and i would be looking at the timing on that bank. Maybe a slipped timing gear?
Old Oct 24, 2021 | 09:26 PM
Paul Waterloo's Avatar
Paul Waterloo
I would not be worried about those cam deviations. I would just monitor and record their values every six months to a year. You need to figure out if there is a trend. I would say they are better than most out there.
Old Oct 26, 2021 | 09:00 AM
Eurocarguy911's Avatar
Eurocarguy911
This is an 03 car which would make it a three chain. What would cause the cam deviation being so high? I thought that the cam deviation was caused mainly by chain guide wear.
