996 Forum 1999-2005
Advise needed
Old Oct 3, 2021 | 11:01 AM
Mike Murphy's Avatar
Mike Murphy
Originally Posted by MOWMOW;[url=tel:17702830
17702830[/url]]Jeeze.....this is a messed up repair and sorry to disappoint the troll hunters. The shop wants to send the engine out to have the IMS tensioner guides replaced.
My question is, I know the variocam chain tensioner has guides but does the IMS tensioner also have guides ....and is that possibly the cause of fuel trim issuses???
I would not go tearing into the engine unless you certainly know you need to. The fuel trim issues could be unrelated to the IMS tensioner pad.
Old Oct 4, 2021 | 03:25 PM
Dr_Strangelove's Avatar
Dr_Strangelove
1999 has been in local shop for almost 2 years. Initial repairs were both variocam selenoids and guides...IMS swap.Fuel trim issues followed with CEL. Shop repaced fuel pump, o2 sensors, coil packs,
@MOWMOW If I'm understanding the first post then they had at least the heads removed initially to replace the Variocam actuators and guides, and now they want to completely disassemble the engine on a second go-around? I'm not asking to count your money but I'm imagining you're in pretty deep already - and they want to go deeper. Do you have any access to another shop you can take this to for another opinion? The first post sounds like a witch hunt and the second sounds like they finally found the issue. EDIT: or another issue.
