Cam Solonoid P1530
Update. Replaced solenoid but still had code. Bought Durametric and deviations were 4 on bank 1 and 0 on bank 2. No immediate change in rpm when solenoid 1 activated but eventually starts to run just a little rough. Activating solenoid 2 and engine dies. Reving engine deviations for bank 1 go to 25+ and slowly come down at idle (took about 2 min). So appears bank 1 actuator is sticking. Tried LiquiMoly engine flush to try to loosen/dislodge but no help. Took it all apart again and pulled cams and actuator. Plunger was very stiff and when I pulled it out it had green o-ring material ripped. So waiting on new actuator, cam plugs and loctite 5900 to come in and hopefully have it put together end of next week. Guides are all new from rebuild last year. Pulled oil pan too to check for anything but it was all clear. I have LN IMS Solution so I haven’t cut open metal oil filter yet to check it.
It's a real shame these are not rebuildable, a 20cent o-ring failure will cost a grand $$$$ to fix. Bad Engineering..
Out of curiosity, in the photo showing green o ring debris, an o ring groove is visible. I have not had the opportunity to see an actual actuator, so I ask, is there another "inaccessible" o ring groove that makes this deemed un repairable?
Godspeed!
Dave
Godspeed!
Dave
Dave, yes, that o-ring doesn't go on the grove you see in the pic, it much further down inside the actuator and is inaccessible due to manufacturing techniques ie. friction welding and staking/brading..
kbatl, such a shame you need to replace the actuator but thanks very much for the update as it completes what to look for when oneself experiences the symptoms you've described.
Have you checked whether the removed solenoid still works (using a 9V battery)?
Update, and hopefully final one. Got it all back together after replacing the bank 1 actuator. No codes, runs great and durametric actuates both cam actuators now. Shows bank 1 deviation of “4” and bank 2 of “0”. Was expecting zero on both sides since all chain pads are new on both sides.
Debating on keeping it as next project is GT3 LCA’s and other suspension bits to get more camber. Outside of tires getting chewed up at track. Goldcrest dialed in as much camber as they could while keeping toe in spec. Thinking of selling and moving to something more track ready.
Yes, the original solenoid worked (I think I tossed it though). Since the new actuator came with a already installed solenoid, I’ll try to sell the one that was used for 200 miles.
thanks for input.
Kevin
thanks for input.
Kevin
The following 3 users liked this post by kbatl:
