Applied a coat of RejeX and...
#61
Originally posted by Orient Express
Since I am the "discoverer" of Rejex for use on Porsches, I thought I would weigh in with my observations.
#63
I stand corrected.
I should have said that I am the original facilitator that allowed all of you gearheads to discover the benefits of Rejex, for without my initial reporting of it, we would not have been able to expand the discussion around surface coatings to include Rejex.
If the fellow that does own the rights to this product reads this board, I'd like to extend a big Thank You for a product well done!
#65
That's strange, when I first discovered the product via Car and Driver, I emailed him. I asked if it was ok for my seal grey Porsche and if my friend who runs a car care company could become a distributor. I got an reply a day or two later...That's how I found out he too was a seal grey owner.
#67
He recommended it here last summer.
#68
getting back to topic...
does this rejex also assist in getting water to bead off windshield, ala 'rain-x'? also, does any one have experience with BOTH rejex and aqua pel?
thanks , j.
thanks , j.
#69
Rejex will act just like RainX in letting water slide off. This is assuming that your windshield is clean. I get the exact same effect as RainX, and bugs don't stick either.
I'm glad to see everyone is jumping on the Rejex bandwagon. The more shiny bug free Porsches the better
#71
Kirby... My PCar with minor dusting is also still clean and shiny after 3wks and I did not use rejex. Rain slides off. The window cleaner I use makes bird droppings and bugs wipe right off the windows and my finish makes cleaning road debris off a snap, and I could go on. My base application last from 3-5months depending on general road exposure and weather conditions.
Did you strip your finish down to clean paint before applying? By using this product are you hoping for one application and eliminate multiple coats? Don't understand the "motive" for using a product that as I understand, was designed for extreme airplane surfaces and such.
I know behind any shiny pcar we'll find a happy owner.
#73
Titan
I don't do anything special before I apply the Rejex. When I first got the car it was detailed by the dealer then when I got home I just wiped the car down and used some detail spray to clean it. Then I applied the rejex. Since then I've haven't washed the car and just wipe down with detail spray, CA duster or a damp rag depending on the conditions. I never wash the car and rejex is the only process I do. Takes about 30minutes to do the entire car. I know the 12hr curing is a bother to you, but since I don't drive my car everyday it's not a big deal to me.
The only 'motive' I have is that it's easy to apply and seems to do a pretty good job of keeping the car clean. This last time was the first time I rejex'ed the inside of my rims and that was the final proof for me that this stuff works. 500+ miles and still no brake dust seems to stick to the inside of the rims. Granted I wipe with a damp paper towel once a week, but before rejex the brake dust build up would have been a lot more now it's minimal.
I know there are proably other product that do a similiar or better job, but in my case for the ease of use and what it does I'll stick with Rejex...for now.
It really doesn't matter what everyone uses. It's the smile on the face after we've cleaned our cars that matters and is the overall 'motive'
