Oil Pressure Instability
So it will save almost an inch of ground clearance.
Chris at CTS was quite generous to share his data from the 24 hour run at Thunderhill in 2017. Data above is from this run that he published on his blog. Here is a plot of one lap of which there were 680. From top to bottom: RPM, Oil Pressure, Oil Level, Lateral & In-line Acceleration.
-It's immediately obvious that the pressure drop issue does not exist. Oil pressure follows RPM's very well. Lowest pressure seen is 3.6bar at 3500 RPM. There is no pressure loss due to braking or turning. There are, however, very fast spikes of pressure loss. A closer look shows these occur at around 5850 rpm when accelerating and 5600 when decelerating. The difference in RPM's is likely hysteresis of the mechanics. The drops are very fast, much less than a second, they only drop down to 4 bar(~60psi) or so, and are NOT due to air being pulled into the system. Certainly not a threat to the engine. Pointing this out to Chris, his quick reply was that this is from the variocam opening and closing. There is a brief blip in the oil pressure.
-The oil level(green) is a gauge in the dry sump oil tank. It seems to vary quite a bit. Looking at G's, we see it closely follows the lateral acceleration. This is oil sloshing around in the sump tank due to turns. Clearly the level never gets to a point where the pressure is affected. The size of the tank has been made large enough to not allow a dry pickup condition
If we zoom out to catch a rest stop for the car and driver, we see the oil level in the tank maximize. It tops out at around 330mm. The average level when running is about 230mm. If we know the size of the tank, we can easily calculate how much oil pumped into the engine and is just hanging around looking for an exit. I know the tank is cylindrical, but I don't know the diameter. The calculations for a 5" diameter tank and a 10" diameter tank would be 1.3quarts and 5.3quarts of oil lost in the engine, respectively. I need to check with Chris to get the diameter, if he's willing to share, to know the actual value. 5.3 quarts would be a lot of oil doing nothing and would explain why mediocre deep sumps don't work. It's all about the baffling and oil return getting to the pickup. An interesting point is how long it takes the tank to refill to equilibrium: 80 seconds... That's a really long time to have 'lost' oil.
Going back to the Palmer plots, I wanted to see if we can see these fast pressure drop due to the variocam. Sure enough, they are there! Look to the blue arrows. The RPM's at which they occur are slightly different from Chris's car, no surprise. The yellow arrow shows one that seems to be missing. On some laps, there are none. Two things about this: data collection rate on the Aim is slower than the Motec, so it's possible to miss them, and other than diagnostics on the variocam, we really don't care about it relative our problem. So, it's interesting but of no consequence. The take away is that some of the sharp short not terrible low pressure drops we see are due to variocam. Noise.
I can play with this if additional granularity is wanted / needed.
Data will set you free!!
If I recall from earlier in the thread, Chris placed the sensor at the cooler which is post filter and the last stop before heading into the mains.
Having a setup with sensors located pre and post consumption areas would give you a great picture of drop in those areas and also an idea if you could steal some excess capacity for other uses.
I will start a new thread for the UIDS so that George can post updates on the CNC progress with pics [EDITED BY MODERATOR]. This thread should be kept clean and about the data. Once in car testing begins on the UIDS the data can be integrated back into this thread.
Last edited by foodbiker; Jun 9, 2021 at 01:51 PM. Reason: No antagonistic comments
Also I need to correct the statement "The rod bearings fail first." I have never seen a failed rod bearing without the main bearing that feeds it being damaged, so the main bearings fail first, and the rod bearings don't fail before they are sent debris by the failing main bearing. Please keep in mind that I don't work on street engines and others' experience with this may be different.
And just to make the point: there is not a single event of abnormal oil pressure in this 25 hour race (also true for the sister car which also ran in this race). That is the standard I had to use in evaluating the system.
Chris Cervelli
Cervelli Technical Service
Realizing that it has been a few years since you developed the dry sump, and production innovation may have occurred to drive down costs, what would it take to produce and at what cost to make it sell-able?
